Thread Tools Search this Thread Rating: Thread Rating: 75 votes, 4.77 average. Display Modes
Old 07-13-2012, 01:10 AM   #221
Vigilante
My Ride: 320i - 2.2 L - 170hp
Send a message via MSN to Vigilante
Originally Posted by J1Productions View Post
Thanks for this diy solid. I think I'm going to tackle this one. What would you rate the difficulty level at? I believe I have all these tools, not sure what fan clutch tools are though.
real easy, 5 out of 10. This is a fan clutch tool:
http://ecx.images-amazon.com/images/...500_AA300_.jpg
But there are many many versions available...
320i Executive Sedan | E46_AV11 | ZF5HP19 S-t | M54B22 | 170hp 210Nm | 09/2000 | 171k | 32.9 MPG
Maintenance
Re-surfaced CH | VC+VCG | CAM/VANOS timing | IMG | NGK-i | BAT+ALT | O2's | GM5 | WP WPP | PSP | DISA | TB ICV MAF | CCV | CAI | OFHG | FP | FF | A/C | FSU | AUC | WSS | BL BD BP | Mango | JFOJ | SB TP IP | springs | Shocks | tires | ASC+ | alignment | E.Flush | Castrol SAF-XJ 75W140 | ZF LGF5 ATF Flush | FCA+FCAB | Struts
Vigilante is offline   Reply With Quote
Old 07-13-2012, 02:45 AM   #222
J1Productions
My Ride: 2000 323i
Thanks for the response. The only thing I'm worried about is removing the bumper and the possibility of messing something up with it. Could I rent this tool at autozone?
J1Productions is offline   Reply With Quote
Old 07-13-2012, 03:12 AM   #223
Nickvjr
My Ride: 2004 330Ci Conv.
Send a message via AIM to Nickvjr Send a message via Yahoo to Nickvjr
My local AZ doesn't carry this tool but you find them for sale every once in a while one this site. I just bought a set from a fellow E46Fanatic & after I do this conversion I will be placing the tools up for sale for someone else to use.
-Nickvjr
2004 BMW 330Ci Convertible
Nickvjr is offline   Reply With Quote
Old 07-17-2012, 02:15 PM   #224
J1Productions
My Ride: 2000 323i
Still going to post the diy video solid?
Old 07-18-2012, 12:19 PM   #225
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Unless my friend wants to do the swap on his car, no for now.
Old 07-19-2012, 04:21 PM   #226
J1Productions
My Ride: 2000 323i
http://item.mobileweb.ebay.com/viewi...id=25429784386
Found this one on eBay. Has the same p/n and claims to be OEM, is this legit? Or should I stay away and stick with Bosch.
Old 07-19-2012, 07:28 PM   #227
Solidjake
Zero. Leaks.
Solidjake's Avatar
That doesn't even have a brand of the fan.
Get this
http://www.ebay.com/itm/BMW-Auxiliar...#ht_1694wt_905
Old 07-19-2012, 10:30 PM   #228
Sweetness
My Ride: '01 325i
Originally Posted by Sweetness View Post
NO go to BMAParts.com RIGHT HERE
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 07-20-2012, 12:27 AM   #229
zander271
My Ride: 6spd ZHP/5sp XI
Yea get that one! Great price!
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 07-31-2012, 06:52 PM   #230
Cobra
My Ride: '00 328i & '06 R6S
i'll be tackling this mod soon, right after i figure out why my e46 can't idle smoothly.
my mechanical fan blew up on me twice in less than 10,000 miles- primarily because the 1st time, the shop didn't diagnose the water pump to be problematic- so i didn't change it, and it had play and wobbled the mechanical fan to death. both times it punctured my hood. plus, i hate the sound and the drag it creates for the revs.
Cobra is offline   Reply With Quote
Old 07-31-2012, 07:12 PM   #231
Sweetness
My Ride: '01 325i
Got mine right here. I'll be doing the before and after idle videos as promised
2001 325i ZCW, ZPP
Old 08-04-2012, 08:58 AM   #232
Solidjake
Zero. Leaks.
Solidjake's Avatar
I would replace the motor mounts as well as a precaution.
Old 08-07-2012, 02:59 PM   #233
Cobra
originally thought that was the problem, but we tested it and there was no slack really. the water pump, however, had a lot of play. though, i'll still change the mounts just because of the age of the car.
Old 08-21-2012, 03:07 PM   #234
lakk25
My Ride: 2005 325i
I would also recommend adding those stupid expanding rivets to the parts list.
Expanding rivets: 51718229003 (4)
51118174185 (as many as your break)
51471919209 (as many as your break)
Just finished this diy in about 2 hrs. Though I broke all those plastic rivet's that hold the air duct on. So I had to order those. But very easy and worth it.
lakk25 is offline   Reply With Quote
Old 08-21-2012, 03:10 PM   #235
Solidjake
Zero. Leaks.
Solidjake's Avatar
Thanks for the added part numbers.
Let us know how the car drives!
Old 08-24-2012, 09:59 PM   #236
xcar360
Past Site Sponsor
My Ride: BMW 318i
Originally Posted by Nervous View Post
Correct.
xcar360 is offline   Reply With Quote
Old 08-28-2012, 09:12 PM   #237
Jlance999
My Ride: 1999 BMW 323i
for anyone who didn't buy the rivets (im assuming you mean the ones for the plastic guard in front of the old puller fan), i realized i had none and used generic door clips (for holding on interiors to door frames) from the closest part store and they fit very solidly, just my 2 cents.
Jlance999 is offline   Reply With Quote
Old 08-28-2012, 09:19 PM   #238
Sweetness
My Ride: '01 325i
I finally am endorsing this mod. 3 days and no problems so far. Fanfreakingtastic. And believe me I was nervous when first installing. If you want to test to see if it works right away, fire up the car and turn the A/C on. The fan should turn on...and your fears will catch the next train out of town.
2001 325i ZCW, ZPP
Old 10-10-2012, 08:27 AM   #239
Aatos
My Ride: 325xi, x5, Audi A8L
Unhappy Bumper removal
All you need is is this:
floor jack and one jack stand
philips screwdriver
I think Torx 20 head
8" extension
ratchet
8mm socket or 8mm wrench
9mm socket
13mm socket
fan clutch tools
OEM electric fan: 17117561757
- Jack up one side of car (I did the drivers side) and put one jack on the metal plate
- Remove the 8mm bolts holding bumper to the fender liners
- Take out the reinforcement bolts with 9mm socket/ratchet/extension
- Slide bumper out (unclip wiring for fogs and horn)
- Take out the top air intake
- The center duct is held by four pop in screws
- Aux fan is held by four 13mm nuts, take them out
- Disconnect the aux fan by the fan shroud in the engine bay
- Slide the fan out
- Put the center duct back in and top air intake
- Put the front bumper back on in reverse order (slide in, put in the two reinforcement bar bolts and the assorted bolts to the liners.
- Next you have to take the mechanical fan out
- Pop out the fan control unit on the shroud and the other wiring and put them to the side
- Take out the 1 torx screw on the passenger side top and loosen up the fan shroud
- Use the fan clutch tool to loosen the bolt and take out the assembly
- Take your electric fan and slide it against the radiator and screw in the torx screw
- Plug the electric fan to the connector where the aux fan was plugged into
- Place back the control unit and the other wiring to the electric fan shroud
Viola, you're done.
I will make a DIY video later.
Thanks for this info. I have gotten as far as 'remove reinforcement bolts', but I can't find them.
Aatos is offline   Reply With Quote
Old 10-11-2012, 08:36 AM   #240
Solidjake
Zero. Leaks.
Solidjake's Avatar
Lay down and look under the bumper, you'll see two big metal bolts.
aux, auxiliary, behr, bosch, bumper, clutch, damage, electric, engine, explode, fan, hood, manual, mechanical, mount, mounts, removal, swap
