Thread Tools Search this Thread Rating: Thread Rating: 74 votes, 4.82 average. Display Modes
Old 03-14-2013, 02:46 PM   #281
Dave1027
My Ride: '06 IR zhp coupe
Very interesting thread. Begs the question, why wasn't the car this way from the factory?
Old 03-14-2013, 04:54 PM   #282
FenderGuy05
My Ride: 2002 BMW 325i
Hey Jake do we need to order 4 of the expanding rivets to do the swap, or is this if you break the ones as you remove them?
I have the fan, arrived today, and was curious if I need to swing by the dealer for these parts before the swap or not.
Thanks.
FenderGuy05 is offline   Reply With Quote
Old 03-14-2013, 11:07 PM   #283
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Thanks.
X2...
Build Thread | S54 Vanos Thread
-TTFS Engine/SMG Tune- SGT Headers/Sect 1/SCZA- Evolve Eventuri- Sprint Booster V2-
-UltraGauge- Orion V4's- CF Lip/Console/Diffuser- VIS XTS CF Hood- LED Fogs- Valentine One- Turner 15F/12R Spacers-
WOLFN8TR is offline   Reply With Quote
Old 03-15-2013, 12:37 PM   #284
eweis
My Ride: 1999 328i
Thanks.
You'll only need those if you break them. I didn't break mine. If you take a few minutes and you're careful in prying them out with pliers and screwdrivers and stuff like that, you can avoid breaking them. Just in case I did break them, I was able to find some at Advanced Auto that were almost the exact same thing. I just returned them later.
eweis is offline   Reply With Quote
Old 03-15-2013, 01:30 PM   #285
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
You'll need them if you break them (which will most likely happen)
Old 03-15-2013, 01:33 PM   #286
FenderGuy05
Where are the for exactly? Removing the fan shroud only took removing a torx screw and one rivet.
Old 03-15-2013, 01:34 PM   #287
Solidjake
Zero. Leaks.
Solidjake's Avatar
Holds the center air duct in place.
Old 03-19-2013, 01:34 PM   #288
FenderGuy05
Got the electric fan put in in place of my mechanical fan on Sunday. Going to have my aux fan pulled in the next couple weeks. No issues at all, car runs great and the fan will make DIY jobs so much easier. I always dreaded removing that fan. Using my OBC, coolant/engine temp was running smoothly at 93-95 for my entire test drive once warmed up.
Old 03-19-2013, 05:57 PM   #289
Danoff
My Ride: '04 330i ZSP
So apparently the reason for the mechanical fan was for the transmission rather than the engine. My attempts at tranmission temperature have failed. We may not have access to it after all.
Danoff is offline   Reply With Quote
Old 03-19-2013, 06:20 PM   #290
samson
My Ride: 05' 330i
Send a message via AIM to samson
Not sure what the big deal is with removing the mechanical fan, mine was a breeze to remove when I replaced it with the electric fan
Sent from my SCH-I535 using Bimmer App
samson is offline   Reply With Quote
Old 03-20-2013, 12:40 PM   #291
FenderGuy05
Honestly, I figure there are coolant lines running to the transmission, so as long as the engine temp is alright, the trans temp should be too.
Old 03-22-2013, 11:54 AM   #292
TheFix330i
My Ride: 2003 330i
I bought the Behr fan, actually I'm on my second, part # 8EW 351 038-391 ECS Tuning # 2568885 ( http://www.ecstuning.com/BMW-E46-330...Fan/ES2568885/ ) . So my question is that as I have seen detailed in this diy I removed the pusher auxillary fan and put this fan behind the radiator plugged it in and the first fan worked for 3 days then stopped. I threw an e fan code of 19 7d on my peake reader. I bought the first fan from a guy here on the forum and since it really isnt his fault the fan quit working I just chalked it up as bad luck with nowhere to return it. I then bought one from ECS Tuning and nothing. what do think is wrong?
I checked fuse and wiring could it be that I have an auto? Is there something else i should look for?
TheFix330i is offline   Reply With Quote
Old 03-22-2013, 12:37 PM   #293
EDWAGON
My Ride: 2004 325xiT
I wonder if anyone will be able to get the transmission temp after MOD and compare it to someones trans temp with the mechanical fan. Need both parties to have infared temp reader gun perhaps?
EDWAGON is offline   Reply With Quote
Old 03-22-2013, 12:46 PM   #294
Sansho
My Ride: 2001 325i
What's that mean? You installed it, and let the engine idle until it started to go into the red zone or ? The fan won't turn if, for example, you turn the a/c on. Did you clear the codes after you installed the new fan and is there a fan code still being thrown?
Sansho is offline   Reply With Quote
Old 03-22-2013, 02:02 PM   #295
TheFix330i
My Ride: 2003 330i
No i didn't let it overheat but the obd II 7.0 function showed 100 degrees C. I then shut the car off. I didn't clear the codes. I thought once the car registered a new fan it would clear itself? Yes it still throws a code. The first fan I installed was from a guy on the forum. It worked for 3 days, It ran constantly. it only turned off once I turned the car off. then quit working at all while I was cruising down the highway. I thought It was just a bad fan.
Old 03-22-2013, 02:51 PM   #296
Sansho
My Ride: 2001 325i
The fan is activated by the car computer based on these inputs:
* Coolant temperature measured at the lower radiator hose
* Calculated catalyst temperature
* Vehicle speed
* Battery voltage
* Air Conditioning pressure (calculated)
You should clear the codes with your Peake reader. It's possible the sensor in the lower radiator hose is acting up - that's one of the inputs the computer uses to turn on, as it senses the temperature of water exiting the radiator. Check a wiring diagram, you may be able to short the wires together, simulating the switch closing, to see if the fan will turn on. The little black box that sits on top of the radiator, on the passenger side, has also been known to fail.
Old 03-22-2013, 03:47 PM   #297
TheFix330i
My Ride: 2003 330i
[QUOTE=Sansho;15275186]The fan is activated by the car computer based on these inputs:
* Coolant temperature measured at the lower radiator hose (new with only 8K miles on it)
* Vehicle speed
* Battery voltage-new battery as of August of last year
* Air Conditioning pressure (calculated) my a/c compressor is not running because my mechanical tensioner sheared its bolt when my mechanical fan blew apart! Since its been cold I haven't fixed it yet.
Old 03-26-2013, 02:24 AM   #298
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
Bosch vs Behr. Which is a better fan?
Don't know if Bosch is better than Behr. Bosch is an OEM supplier of the fan, Behr may be too.
How safe is installing a 'used' Electric Fan?
delmarco is offline   Reply With Quote
Old 03-27-2013, 09:14 PM   #299
straight_beamin
My Ride: 2000 bmw 323i
If it came off a running car why wouldnt it be safe ^
straight_beamin is online now   Reply With Quote
Old 03-28-2013, 12:14 AM   #300
delmarco
Jake said these fans last around 130,000 miles before the bushings fail.
The used one I was buying was coming off a car with 132,000 miles.
aux, auxiliary, behr, bosch, bumper, clutch, damage, electric, engine, explode, fan, hood, manual, mechanical, mount, mounts, removal, swap
