Thread Tools Search this Thread Rating: Thread Rating: 75 votes, 4.77 average. Display Modes
Old 03-28-2013, 08:39 AM   #301
straight_beamin
My Ride: 2000 bmw 323i
Its probably hit or miss. If its a good deal try it out. Its only a fan why not
straight_beamin is offline   Reply With Quote
Old 03-28-2013, 06:11 PM   #302
Pottsy
My Ride: 2004 330i zhp
Very helpful thread
Sent from my DROID3 using Bimmer App
Pottsy is offline   Reply With Quote
Old 03-28-2013, 07:43 PM   #303
always-there
My Ride: 2002 BMW 330I
Seriously considering this swap. I know I was told earlier it'd be a good mod, but didn't listen. Will do now !
Old 03-28-2013, 07:44 PM   #304
lszlszx
My Ride: 1.8T, XC70
If the loud fan noise that I hear is the mechanical fan, I am looking forward to
doing this. Reducing drag on the engine is great, too.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 03-28-2013, 08:36 PM   #305
FooFighter94
My Ride: 2001 325Cic
Just did this to my car last night, I can notice a large difference in the "feel" of the car when accelerating. The install was pretty simple but I haven't actually noticed the fan running. Granted, it is 30 degrees outside today. Does it work the same way as the AUX fan? Thus working only when needed?
WVU Mountaineer
-2001 325Ci Convertible Slushie
-Orient Blue Metallic
-Koni Yellows, Otherwise hella stock
FooFighter94 is offline   Reply With Quote
Old 03-29-2013, 12:34 PM   #306
FenderGuy05
My Ride: 2002 BMW 325i
Yes it does. When I did the swap I drove around and was getting out every so often until I saw the fan running. Took a while of driving, and then sitting in aparking lot.
Taking the aux fan out tomorrow. No issues to report as of yet. Car runs great, and I can't wait to do some work tomorrow without having to remove the damn mechanical fan!
FenderGuy05 is offline   Reply With Quote
Old 03-29-2013, 12:58 PM   #307
Sansho
My Ride: 2001 325i
Taking out the front pusher fan opens up a nice direct airflow to the radiator. I had some black aluminum screening (like on a screen door) handy, so I put that across the front of the radiator, to keep bugs and stuff out of the radiator fins, which has worked well.
Sansho is offline   Reply With Quote
Old 03-29-2013, 01:25 PM   #308
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
I live in Las Vegas were it gets up to 110-115 in the summer. My Mechanical fan runs all the time in the summer and is annoying. Here's the thing if guys like me and several others are doing this Mod in extreme temp locations with NO issues. Why do other guys have reservations that live in mild climates, they say it doesn't seem necessary. If you live in mild climates it should be the first Mod you do. This isn't about adding extra cooling BTW.
Build Thread - S54 Vanos Thread
TTFS Engine/SMG Tune - SGT Headers/Sect 1/SCZA - Evolve Eventuri - Sprint Booster V2
UltraGauge - Orion V4's - CF Lip/Console/Diffuser - VIS XTS CF Hood - CSL Trunk - Valentine One - Turner 15F/12R Spacers
WOLFN8TR is offline   Reply With Quote
Old 03-29-2013, 07:16 PM   #309
lszlszx
My Ride: 1.8T, XC70
Is it because the pusher fan smaller, than the electric one replacing it?
Old 03-29-2013, 11:16 PM   #310
Sansho
My Ride: 2001 325i
The front pusher fan has a shroud/frame around, which comes out when you remove the fan. As I recall, the pusher fan is a bit smaller than the electric puller fan behind the radiator.
Old 04-20-2013, 11:37 AM   #311
Foxtrot_Uniform
My Ride: 325Xi
I just used this guide two weeks ago when I did a total cooling system refresh. Not only am I running a hair cooler I am now getting over a 2MPG AVG bump in gas mileage! Can't beat it!!!
Foxtrot_Uniform is offline   Reply With Quote
Old 04-21-2013, 06:21 PM   #312
SeattleLSB
My Ride: 2003 330XI, 2003 M3
Anyone notice A/C not getting as cold? I did the mod but I have not removed the front fan behind the bumper yet.
Joe
2003 LSB/BLK M3/SMG/Premium/Cold Weather/Nav
2003 AW/BLK 330XI/AT/Sport/Premium/Cold Weather
SeattleLSB is offline   Reply With Quote
Old 04-21-2013, 09:31 PM   #313
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Joe
My AC is running exactly the same as before. I'm sure it's because you still have the Aux fan installed. It's blocking the air flow. Before the mod the Aux fan runs when the AC is turned ON, now it's just blocking the air flow. Look at these photos.
Old 04-28-2013, 08:56 AM   #314
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
holy dirty condenser
so the aux fan removed wouldn't raise ac temps a bit?
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 04-28-2013, 09:00 AM   #315
Foxtrot_Uniform
My Ride: 325Xi
When I removed my aux fan I was surprised how much crap was wedged in between the fan and condenser. You WILL need to remove the fan and clean it out.
My AC is colder if anything... Certainly not hotter. Plus the extra 2MPG is awesome and worth it in and of itself!
Old 04-29-2013, 06:30 AM   #316
wasp9166
what did ya clean it with? i don't have access to hose, maybe carb cleaner or brake cleaner would work on dirty cond?
Old 04-30-2013, 12:18 PM   #317
El Polo
My Ride: 99 black 328i
Just did it this weekend.
I love it. Engine revs freely, car no longer sounds like an 18 wheeler.
No change in engine temps, but I haven't removed the front aux fan yet.
El Polo is offline   Reply With Quote
Old 05-04-2013, 12:44 PM   #318
azshorty
My Ride: Hellrot 323CI
Got my fan from BMAparts.com. I want to do it before bfest in two weeks.Is it necessary to run a lower temp t-stat?
Is there a lower temp switch available for this conversion?
azshorty is offline   Reply With Quote
Old 05-04-2013, 12:56 PM   #319
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
I did my swap and everything else is stock, no issues. Love this mod, I also gained 1.3 mpg. I installed a UltraGauge to monitor the coolant temps. It has alarm settings so if the coolant temp gets to high a alarm will sound. It also checks troubles codes and clears them. Click on the link in my sig.
http://www.ultra-gauge.com/ultragauge/index.htm
Old 05-06-2013, 09:15 AM   #320
Ballistic325
My Ride: slow and steady
Ultra gauge is a neat little device. Just keep in mind though that it will rely on the coolant temp sensor if that's not reporting accurately, we'll then nothing can save you
What I'm getting at is that if you haven't already, it might be a good idea to change the sensor. Good luck!
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
aux, auxiliary, behr, bosch, bumper, clutch, damage, electric, engine, explode, fan, hood, manual, mechanical, mount, mounts, removal, swap
