Old 06-09-2011, 09:32 PM   #1
sellsellsell2000
My Ride: E46 seden
Send a message via AIM to sellsellsell2000
DIY: Built your own Shifter Boot Base without sacrificing your original
Okay, if you purchased some shifter boot online without a base. Not to worry, there are alternative ways to built your own shifter boot base without sacrificing your original.
First, pick this up ~ Hanger Tape
Use the 'Hanger Tape', use it and follow the area where the shifter base sits. Good thing for this is that it has holes where you can use electrical ties to secure it.
Once you have secured your shifter boot base, it is better to leave a little bit room for the fabrics to tug along side of the base.
Now, glue down the fabric on to the base.
Here is the final product.
BEFORE
BMW /// 323i
OEM M-Tech II front & rear bumper /// Cluster Ring /// Grimace Fog Lights /// CCFL angel eye
330i Diff /// REMUS Exhaust /// Heat Shield Cold Air Intake
sellsellsell2000 is offline   Reply With Quote
Old 06-10-2011, 05:25 AM   #2
snowborder142190
My Ride: 08 335i coupe '09 m6
You could just reuse the oem bracket but nice solution!
Sent from my iPhone 4 using BimmerApp
snowborder142190 is offline   Reply With Quote
Old 06-10-2011, 11:34 AM   #3
sellsellsell2000
My Ride: E46 seden
Going to do another 'base' frame with clips. More pix soon.
BMW /// 323i
