Old 06-10-2011, 03:56 AM   #1
pyroboy024
My Ride: '04 325Ci
Exclamation '04 Power Steering Hum at 800-1200 RPM... Help?
I Have an '04 325ci and i believe i have a LF-30 power steering pump installed but i could be wrong, i have yet to stuck my head under the car.
My problem is I am getting a hum/ very light vibration at low RPM's ranging from 800-1200 RPM. But once i get going and on the road, and the rpm's climb higher i dont notice a thing and in fact seems very quiet and smooth. So I'm not sure what is going on my here... my power steering fuild level is fine and i recently did a flush hoping it would help, but it didnt... So please can anyone shed some light on my issue...
PS this is only a sound/light vibration in the floor boards i have never experienced a loss of power, its just embaressing parking in and out of spaces as you turn the wheel
pyroboy024 is offline   Reply With Quote
Old 06-10-2011, 04:01 AM   #2
snowborder142190
My Ride: 08 335i coupe '09 m6
When you did the flush did you change the reservoir? It has a filter in it which can become clogged and deprive the pump of fluid and make the sound you are describing.
Sent from my iPhone 4 using BimmerApp
snowborder142190 is offline   Reply With Quote
Old 06-10-2011, 04:15 AM   #3
pyroboy024
My Ride: '04 325Ci
mmm no i did not... ill give that a try i forgot about the filter in the reservoir... if anyone else has any ideas that would be great! i hope its just a reservoir issue
Old 06-10-2011, 10:52 AM   #4
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
might be just your pump dying on you....are you 100% its coming from the pump?
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 06-10-2011, 07:01 PM   #5
pyroboy024
My Ride: '04 325Ci
100% sure its from the pump i can put my car in neutral and i get the same effect, and if i rev it to 1500 rpm and turn the wheel the sound is gone...
Old 06-10-2011, 07:46 PM   #6
330ciandr6
My Ride: .
If the tank is full of fluid then it's probably your pump starting to go out.
2004, hum, lf-30, power steering, pump
