Old 06-12-2011, 03:43 PM   #1
Brinkley
My Ride: 99 328i, 07 z4 3.0
Manually moving power seat
The driver's seat in my newly purchased vert is stuck in the fully back position. All functions except forward and backwards work, removing the front bolts is obviously no problem, but the rear ones are completely inaccessible.
I have read online that there is a method for manually moving the motor in this situation but have had no luck find the procedure. Any help is greatly appreciated.
Brinkley is offline   Reply With Quote
Old 06-13-2011, 01:44 AM   #2
dirsh
Hawaii 3.0
dirsh's Avatar
My Ride: sanbyaku sanjuu
Can you raise the seat? If so lift it as high as it can go and see if you can disconnect and remove the motor
Hello dirsh it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
dirsh is offline   Reply With Quote
Old 06-13-2011, 09:06 AM   #3
Brinkley
Thanks for the reply. Yes I have the motor unbolted and I am able to start moving the seat, but not very far and the motor doesn't want to come out of there.
