| View Poll Results: Which kit? | |||
| Rogue Engineering $185 two pulleys |
18 | 39.13% |
| UUC $200 two pulleys |
5 | 10.87% |
| Turner $250 three pulleys |
17 | 36.96% |
| Other, please specify. |
6 | 13.04% |
| Voters: 46. You may not vote on this poll | |||
#61 |
Mod
Not yet. I'm thinking about getting an intake first and then get some heat resistant foil to cover my entire intake track with.
Follow my cross country drive to Bimmerfest West 2013
http://forum.e46fanatics.com/showthread.php?t=987217 ![]() Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide |
#62 | |
![]() buddy look up underdriving the crankshaft |
#63 | |
To be really basic, put a manual transmission in third gear and try to go - you accelerate slowly. Do the same in first gear and you take off, despite your engine having the same power output. With the transmission in the wrong gear, there is a huge efficiency loss between the engine and the wheels, and that's all wasted power. It's all about setting the proper ratio to allow the most power to the wheels; the same applies to pulleys. I'd like to do this on mine, but I haven't had time or done enough research to decide on who to buy from. Good thread though!
#64 | |
#65 |
Banned
Turner without question. Go with the guys who build race cars.
#66 |
Just put Rogue Engineering pulleys on mine. All those other companies are back ordered...and they were cheaper because they don't have an alternater pulley, which is a pointless item (unless you are performing maintenance, in which case I'd go OEM.)
I also have the Stewart High performance water pump and a long tube intake...car is far and above what I expected! Sent from my DROIDX using Bimmer App
#67 | |
i wanna get a dinan long tube in with a 3.38 and a aa tune and i should be happy for a while |
#68 | |
#69 |
Mod
Heat resistant tape!
#70 |
Why does it matter if the car is a m or not. There shouldn't be a difference. If it doesn't work for non-m why would it work for a m?
#71 |
If any one question"s what TMS power pulleys will do feel free to call them Its a 1 800 number ,Theyll be glad to assist you with there facts and knowledge !
AJV Youre more then partially right , Power pulleys will assist you Reduce loss of drag and add more HP and Tourque Its a simple as that , For those who seem to differ let me ask you this , Its known that splitters and wings help the areo dynamics and etc of a car right ! Whould wouldnt power pulleys not play a role when they reduce drag ? |
#72 | |
My Ride: M3 & 323Ci (sold)
![]() ![]() OEM CSL WHEELS - OEM CSL BRAKES - OEM AUTOFOLD MIRRORS - CSL TRUNK - CSL DIFFUSER - AA SPORT TUNE - AA PULLEYS - BILSTEIN PSS9s - AUTOSOLUTIONS SSK CF CSL RACE LIP - NAVI HU - BMW PERFORMANCE CF STRUT BAR - BMW GROUP-N MTRMTS - UUC SS BRAKELINES, TRANS MOUNTS, RTABs - 4.10 BMW M-SPORT DIFF |
#73 | |
While an engine that redlines and ends 2K rpm before doesn't is the reasoning.
#74 | |
*but yes, if you mess with the harmonic balancer you're in for trouble
#75 | |
Do you own a set of pulleys ?To justify that on the E46 non-M very very little ? From what I understand this will be effective at 5 k rpm"s ! On going debate ..Like I said If any one has Installed them and has an actuall dyno on them showing me no gains at all then Ill shut my mouth untill then I stand bye TMS and there product! Last edited by 323I00; 06-14-2011 at 02:26 PM. |
#76 | |
And no that example and what you said are not the same.
#77 | |
I simply wrote "Power pulleys will assist you Reduce loss of drag and add more HP and Tourque Its a simple as that " "Why wouldnt power pulleys not play a role when they reduce drag " What does that mean ^ , seeing Its not clear enough 4 u , Power pulleys will give you the loss HP and Tourque that It produces from less drag time traveled with the oem pulleys. Last edited by 323I00; 06-14-2011 at 04:34 PM. |
#78 | |
That being said, My M52tub28 is not stock by any stretch...and after this last set of mods I am pretty sure I'm approaching 19X RWHP and that is w/o headers. There is a definite feel with the pulleys and the Stewart pump. And sure I could have gone with OEM, but it's much more fun to blow by 330s and point to the stinger ![]() Jake, I'm not sure how this would affect an auto...but if you want to you should go with RE, they came to my door for $202.xx in 3 days. Install was easy cause I was replacing my belts, pulleys, tensioners and cooling system. And since you have the electric fan, it will be much quicker Good luck!
#79 |
Ungh... You can call it drag or whatever you wish... You get nothing at the crank, NOTHING. All pulleys do is decrease the speed at which accessories are spinning to their lower operating limits. There is a factor of safety designed into car systems, and one of those safety factors is spinning accessories faster than absolutely necessary. By lowering the speed at which they spin, they aren't drawing as much power/energy/whatever you want to call it from the engine. As a result, the saved power can be directed to the rear wheels (and transfer case/front wheels for you XI people).
The amount of WHP you will gain (or lose) depends on lots of factors: - What was the factor of safety on the stock pulley setup? - How much friction was present in the stock setup and how much is present in the aftermarket setup? - How loose/tight is the belt? Yes, the tension of a belt has considerable implications on how much power something draws - I design heavy equipment that is often belt driven, so I know what I'm talking about. There's lots of theory behind pulley setups, intake systems, exhausts, etc. The magnitude of improvement (if any) is dependent on the original design, which BMW is often quite good at.
#80 | |||
![]() Quote:
![]() back to topic, you didn't answer the question I answered for you. Do you have these "power pulleys" installed on your car?
