Old 06-13-2011, 06:47 PM   #1
E46330XI
My Ride: 2001 330XI
HELP! Stripped O2 sensor
Hey guys,
I am having a problem just like the title says. I have replaced all but one O2 sensor because the last and hardest one to get to stripped!! Any clue on the best way to get it off? I used a brand new 22mm O2 sensor socket. All the other ones came off fine. I even sprayed it down with that anti seize spray or loosening spray, cant remember what its called. Would heating it help?
E46330XI is offline   Reply With Quote
Old 06-13-2011, 07:37 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Heating can help, but don't overdo it.
Old 06-13-2011, 08:25 PM   #3
E46330XI
My Ride: 2001 330XI
Is there any tool I could use? Like an angled vice grip or something?
Old 06-13-2011, 08:35 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
If you're referring to the post cats I cannot help since I never did them.
Old 06-16-2011, 01:55 PM   #5
Spyder_Venom
My Ride: 01 325 CI
As suggested, heating is normally how I get them out. If that doesn't work, cutting the head off the sensor and using a bolt extractor kit usually will do the trick (http://www.google.com/products/catal...d=0CIYBEPMCMAM).
There as been a time or two they have been so badly rusted in, I've broken the 02 out of the bung. There is always the risk of damaging the threads, but worst case you can weld on a new bung.
Spyder_Venom is offline   Reply With Quote
