Old 11-08-2012, 06:41 PM   #1
alinfaraonu
My Ride: 320i
hy
HY. I hawe bmw 320i and my problem is when the engin is cold same light caming on like:engine (yellow)eml,and dsc/hand brake yellow It has happened to someone.I am very scared please help me.
alinfaraonu is offline   Reply With Quote
Old 11-08-2012, 07:27 PM   #2
farmdog
My Ride: Acura TL
Hy.....your dash looks like a Christmas tree on the fourth of July.
farmdog is offline   Reply With Quote
Old 11-09-2012, 05:47 AM   #3
alinfaraonu
My Ride: 320i
I need help man no talking like this bad anser u give me (
Old 11-09-2012, 06:47 AM   #4
lucky_doggg7
My Ride: 2005 M3
OK, let's start with an easy one, on the right corner of the headlamp cluster, you have a burned out turn signal or a headlamp bulb burned out. Those are easy to fix even for the mechanically disinclined. It's just a matter of replacing a bulb.
Onto the traction control light being on, it is my guess that a wheel speed sensor has failed or the wiring to the sensor is compromised, or even perhaps the connection is bad. As for which corner is affected, it's not possible to tell you here.
Your EML light, if were to guess, the temperature thermocouple probe that detects catalytic converter temperature is at the end of its useful life.
The check engine light could be multiple DTCs; it's not possible to tell you what might be the problem as there are too may possibilities. Take it to your BMW specialist and have a trained mechanic connect your car to a BMW GT1 diagnostic tool to reveal all the DTCs recorded in the ECU.
Old 11-09-2012, 07:43 AM   #5
alinfaraonu
My Ride: 320i
I change the spark plugs and engine light gone neaw,onli the EML on and 2 light on, but wen the engine is hot after 30-35 min on after i off 1-2 min end start again light gone an engine run normal, but this light coming onli morning time wen is colod !!!! Sorry for my english
Old 11-09-2012, 09:36 AM   #6
Platinum Plus Quality
My Ride: M54B30
Cooling | Maintenance | Vacuum | Suspension | Costs
"Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs
Old 11-09-2012, 09:38 AM   #7
jasonbimmer
My Ride: 2001 BMW 330xi
I would check the operation of your throttle body.
also get a code reader stop guessing problems.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 11-09-2012, 09:56 AM   #8
louie586
My Ride: 2013 ATS 2.0T/6MT
I'm dying laughing over here.
louie586 is offline   Reply With Quote
Old 11-11-2012, 06:15 PM   #9
alinfaraonu
My Ride: 320i
Today mecanic giveme this code reader : P0604 ; P1632 ; p1639 ; P1638 .
Some body help me please.
Old 11-13-2012, 02:02 PM   #10
alinfaraonu
My Ride: 320i
No body help me pleaseeee
Old 11-13-2012, 02:34 PM   #11
peytonracer4
My Ride: '00 328i
http://lmgtfy.com/?q=P0604+%20P1632+...0P1638+bmw+e46
Old 11-13-2012, 03:41 PM   #12
trizzuth
My Ride: gobbles oil like a B
My nomination for posts of the year. Hands down!
OP, good luck to you, it takes lots of scrotum to make a post on a largely american site with pretty bad English.
trizzuth is offline   Reply With Quote
