Go Back   E46Fanatics > New Member Introductions
New members check-in, introduce yourselves, and post a picture of your BMW here!
Old 06-15-2011, 10:35 PM   #1
13renton
My Ride: 02' E46 318i
New Member from NZ
Hi
Just joined the forum and just saying hi. I previously owned a 94 E36 320i and decided to make a slight upgrade so bought a e46. Its pretty much just standard low spec entry level one.
Hers a pic of my car.
Would like to get some help from some people as I just did a scan and not sure what some of these error codes mean.
BMW Scanner v1.4.0.7 (14.01.2009) - P.A.Soft, 2008 HW: V144Bn9 Time: 1:47:46 p.m. 16/06/2011
FA coding : /-------- IKE --------\ /-------- LCM --------\
Chassis : E46 E46
Model : 318i 318i
Type key : AZ72 AZ72
Engine : N42B20 N42B20
Gearbox : Automatic Automatic
VIN : NG07484 NG07484
Time criterion : 0302 0302
Paint code : 0372 0372
Upholstery code : H9TT H9TT
FA-stream : 024134129545BF87A5D2 024134129545BF87A5D2
4135D2A19D345D549259 4135D2A19D345D549259
34D75524584564104104 34D75524584564104104
10421241449055251949 10421241449055251949
55544515135145595174 55544515135145595174
D54D4554616591599498 D54D4554616591599498
4586124D84956134984D 4586124D84956134984D
36154185536164585946 36154185536164585946
1759861065254000 1759861065254000
# SCAN START
Unit BMWTNR HW SW-FSW CI DI BI/VI Date Odometer VIN ADFG Algorithm
DME* -> 7.523.838 10 6.x.x 0C 000F 304C 04.02 - NG07484 007484 ME9.2 NG
EGS -> 7.521.759 29 76 00 10 60 22/02 120650 km WBAAZ72090NG07484 000000 GS20
EWS -> 6.905.667 03 08 81 81 07 18/02 120650 km WBAAZ72090NG07484 FFFFFF EWS3
ABS* -> 6.759.073 04 0.0.91 04 0002 0002 04.02 - AA00000NG07484 007484 DSC E46,R50,E85
A/C -> 6.916.882 25 07 15 32 0D 15/02 - - 007484 IHKA E46 PU98/PU99
SRS -> 6.912.755 10 32 32 09 00 20/02 - NG07484 000000 MRS4
IKE -> 6.911.287 12 23 06 53 12 14/02 120655 km NG07484 FFFFFF M35080 - E46 (E46)
LCM -> 6.919.825 15 30 31 30 00 09/02 120600 km NG07484 000000 HC912 - 5 (LSZ2)
ZKE -> 6.914.364 11 20 02 40 10 20/02 - - 007484 ZKE5
MFL -> 0.000.000 01 09 00 03 78 00/00 - - - MFL2
RAD -> 6.902.713 48 49 00 14 09 36/00 - - - Radio ZIS/BM/MIR
VTC1* -> 7.516.207 10 6.x.x 01 0014 3931 03.02 - 0000000 - SKV20 - VVT Bank 1
SPMFT -> 6.916.054 03 03 01 01 01 14/02 - - 007484 SPM E46 Driver
SPMBT -> 6.916.054 03 03 01 01 01 14/02 - - 007484 SPM E46 Passenger
SMF -> 7.036.126 08 0B 01 01 01 10/02 - - 007484 SM 4-channel E46
# USER INFO FIELDS
Unit Date VIN Odometer Assembly Software Service Dealer Tester Program ver.
DME* -> 05.06.02 WBAAZ72090NG07484 0 km 7.522.633 7.522.634 7.512.791 012321 42324 0087160H600B
20.01.05 WBAAZ72090NG07484 38400 km 7.522.729 7.522.731 7.512.791 012321 42324 0087160H650B
EGS -> 05.06.02 WBAAZ72090NG07484 0 km 7.521.816 7.519.736 1.000.000 012321 42324 -
VTC1* -> 27.03.02 0000000 0 km 7.516.809 7.516.810 7.507.493 001001 VDO-P 0104110A620V
# ERRORS IN UNITS
Unit BMWTNR HW SW-FSW ERRORS / SHADOW-MEMORY
DME* -> 7.523.838 10 6.x.x no errors
EGS -> 7.521.759 29 76 no errors
EWS -> 6.905.667 03 08 3 errors
ABS* -> 6.759.073 04 0.0.91 no errors
A/C -> 6.916.882 25 07 1 error
SRS -> 6.912.755 10 32 1 error / no errors
IKE -> 6.911.287 12 23 2 errors
LCM -> 6.919.825 15 30 2 errors / 10 errors
ZKE -> 6.914.364 11 20 3 errors / 2 errors
MFL -> 0.000.000 01 09 no data
RAD -> 6.902.713 48 49 no errors
VTC1* -> 7.516.207 10 6.x.x no data
SPMFT -> 6.916.054 03 03 no errors / 1 error
SPMBT -> 6.916.054 03 03 1 error / 2 errors
SMF -> 7.036.126 08 0B no errors
# ERRORS DETAILS - DTC(hex)/PARAM(hex)
EWS -> 13/06 - Toleration of changing code increased, key 1
0F/FF - Power on reset
03/03 - Toleration of changing code increased, key 0
A/C -> 1C/04 - AUC sensor
SRS -> 50/A0 - Power supply, undervoltage
IKE -> F9/C4 - No CAN message (ASC3)
87/81 - Body bus (K-bus)
LCM -> 13/1F - Diagnostic link U10 defect
14/01 - Wire, brake-light switch, open circuit
Shadow-memory:
33/1F - Sidelight, front right
34/08 - Brake light, left
35/02 - Brake light, right
3E/04 - Rear fog light faulty
3F/05 - Turn indicator, rear left
40/01 - Turn indicator, rear right
41/01 - Low beam, right
45/1F - Sidelight 2, rear right
46/06 - Sidelight 3, rear left
47/1F - Sidelight 3, rear right
ZKE -> 10/01 - Power window: Open circuit Jam protection strip or lost of scaling/Error EKS electronic Passenger side behind
0A/01 - Power window: Open circuit Motor or Relay Passenger door
3D/01 - Central locking system: Short circuit or Open circuit at Motor Tailgate
Shadow-memory:
90/36 - Battery Voltage: Open circuit
95/01 - Repeat blocking: Power window
SPMFT -> Shadow-memory:
00/1B - Low voltage ( U < 8,5 Volt )
SPMBT -> 08/3F - Mirror drive, potentiometer horizontal
Shadow-memory:
00/1A - Low voltage ( U < 8,5 Volt )
04/02 - Mirror drive, potentiometer plausibility
# SCAN END
13renton is offline   Reply With Quote
Display Modes
