Front Axle Seal Install - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 06-16-2011, 07:14 PM   #1
Rickna
My Ride: '01 330xi - '09 IS-F
Looks like I have a leaking sel on the pass side. Are there any special tools I need? What is the R&R prodecure?
Thanx
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 06-16-2011, 09:14 PM   #2
Kubica
My Ride: 2003 325xi
Pry the old one out with a screwdriver. Unless you have BMW's special tool, you will have to use your hands to install. Don't remove the plastic insert yet and use the palm of your hand to make it sit correctly. Remember to remove the plastic and coat the seal in diff fluid.
Old 06-19-2011, 10:21 PM   #3
Rickna
Thanks for your help.
I was thinking-this might be helpful. What do you think?
2001 BMW 330xi
2009 Lexus IS-F
Old 06-20-2011, 09:10 AM   #4
Kubica
My Ride: 2003 325xi
^yeah that looks like the BMW tool.
Old 06-20-2011, 09:24 AM   #5
Rickna
Thanks-much appreciated.
2001 BMW 330xi
2009 Lexus IS-F
Old 06-20-2011, 04:24 PM   #6
TiAgXi
My Ride: e46xi, e46m
Before you purchase a race/seal driver kit, you should know that AutoZone will lend one to you for free.
Make sure to pound the seal in evenly and stop when its flush.
TiAgXi is offline   Reply With Quote
Old 06-21-2011, 09:34 AM   #7
Rickna
Yeah I know. I have a nice collection of tools, I don't mind adding to it.
2001 BMW 330xi
2009 Lexus IS-F
Old 06-22-2011, 08:47 AM   #8
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
this might be redundant but:
- remove wheel
- zip axle nut off with air. (or put car back on the ground with wheel on but no center cap, using a long breaker bar, break nut loose (36mm 12pt)
- remove outer tie rod end (i usually back the nut off 3/4 then hit the ear the tie rod goes through (perpendicular to tie rod shaft/nut). hit hard enough and the tie rod will pop out without having to touch a ball joint separator or messing threads up)
- remove two bolts for the inner ball joints on control arm
- press axle out of hub (tap with hammer)
- pull whole hub assembly towards the back of the car (may have to remove sway bar link)
- remove cv from oil pan/diff (might have to pry a bit, but no worries since you are replacing that seal)
- R&R seal
- put everything back together
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
Old 06-22-2011, 06:37 PM   #9
Rickna
- remove wheel
- R&R seal
Thanks. I am familiar with the axle procedure.
After taking measurements of the axle seal, I found that the seal drivers in the kits won't fit properly. I am in the process of fabricating a driver in my shop.
2001 BMW 330xi
2009 Lexus IS-F
Old 06-22-2011, 08:27 PM   #10
Kubica
My Ride: 2003 325xi
^Just use your hands.
Old 06-23-2011, 07:48 AM   #11
association16
My Ride: 2003 BMW 330xi
I just replaced my left CV axle. Is the axle seal something that I should have replaced at the same time as well? Or does the replacement CV axle come with a replacement?
association16 is offline   Reply With Quote
Old 06-23-2011, 11:37 AM   #12
Rickna
And damage my baby soft skin? LOL Yeah, I coud do that...
2001 BMW 330xi
2009 Lexus IS-F
Old 06-23-2011, 11:38 AM   #13
Rickna
The seals are seperate item. The best time to change the seal is when you have the axle out.
2001 BMW 330xi
2009 Lexus IS-F
Old 06-23-2011, 11:41 AM   #14
TiAgXi
If you don't change the seal out, there is a very good chance you'll end up with a leak.
Old 06-23-2011, 11:58 AM   #15
Rickna
Yup. the 1st axle I replaced, the seal didn't leak. The 2nd time, the seal is leaking.
2001 BMW 330xi
2009 Lexus IS-F
Old 06-23-2011, 01:24 PM   #16
redbull 325is
My Ride: 325xit/6
i pressed mine in with a 3" peice of pipe I had laying around. I wrote up the little how to in case somebody was searching for the procedure.
Old 12-01-2011, 07:14 AM   #17
SaturnX
My Ride: 2003 325xi
Going to be tackling this on the upcoming weekend, any tips for doing the installation by hand?
Kubica mentioned coating the seal with diff fluid, so just a little along the inside/outside of the seal before I press it in?
Thanks!
SaturnX is offline   Reply With Quote
Old 12-01-2011, 10:43 AM   #18
kylek325i
My Ride: 2003 325xi sport
From my experience the seals do not easily pop in and out, i used a seal puller and had to really pry it out. Use care not to marr the bearing pedestal. Definitely coat the whole seal in fresh oil. Take your time on the install so it doesnt go in cocked to one side. I used a hammer and the plastic frame that came on the seal to use as the seal driver. The metal frame on the seal OD is stronger than it looks. GL-
kylek325i is offline   Reply With Quote
Old 12-01-2011, 11:56 AM   #19
Kubica
My Ride: 2003 325xi
I've always been able to line it up and bang it in with the palm of my hand. Just don't remove the plastic ring until it's all the way in. The TIS says to keep the plastic ring until the axle is inserted, then cut it off:
http://tis.spaghetticoder.org/s/view.pl?1/06/10/97
Old 12-01-2011, 11:59 AM   #20
Kubica
My Ride: 2003 325xi
On a side note, do you guys have a vent tube on your front diff?:
http://tis.spaghetticoder.org/s/view.pl?1/06/18/07
