Old 06-16-2011, 03:29 PM   #1
MikeSamteladze
My Ride: BMW M3 E46
Need advice after inspection
Hello, I'm planning to buy BMW M3 E46 and I've ordered an inspection for one vehicle
There was one thing I couldn't understand, it was told that:
There were irregular thumping noises audible while driving at
slow to normal speeds that sounded like a failed hub bearing type noise
Can this be something serious?
What do you think about the condition of this vehicle?
MikeSamteladze is offline   Reply With Quote
Old 06-16-2011, 03:43 PM   #2
eurodriver
My Ride: ///M
The thumping could be anything. My guess is that it is the RTABs or RSMs. However, it may be the subframe. Too hard to tell with that one sentence. The owner of the car should have had more fuel in the vehicle so the inspector could have tested it correctly.
However, that being said, it seems to be in very good condition. I don't think they found too many issues, other than the thumping noise. But, I would investigate that further. What is the mileage and year of the M3?
Where is the car located?
eurodriver is offline   Reply With Quote
Old 06-16-2011, 04:16 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
What? There was a splash shield preventing inspection of stuff underneath...so you don't know about what could be 20 hrs. of diying time...including oil/ps leaks and suspension stuff he couldn't see coz there was something in the 'mechanics' way.
"It felt like a wheel bearing"? Put it on a lift and spin the wheel and listen with a stethoscope.
OP, hope this wasn't a very expensive PPI...if it wasn't, depending on cost of car, you might want to try again.
Otherwise, if you didn't know, figure you'd want to spend about 20-30% of the cost of the car for maintenance the first year or two...very rough estimate.
Just don't count on the car working. It may very well, but it may not. But don't be caught out buying a car you can't afford to maintain is all...and from that inspection, I'm not so sure.
Sorry...you asked! Maybe it's just my suspicious nature.
Automatic or manual? Must be manual... Mileage, cost, and is this car remote from you and you've arranged an inspection, or have you driven it yourself too?
Facebook.com/DMAXstandup
Mangofy your E46!
Old 06-17-2011, 01:26 AM   #4
MikeSamteladze
My Ride: BMW M3 E46
Thanks for your answers. I completely understood you.
It's mechanics 2002, 80600 miles on it
Old 06-17-2011, 08:02 AM   #5
Zchild
My Ride: 2000 BMW 3XXi ZSP
Since it's the mechanics car I would see if I could get him to replace the the wheel bearings prior to sale, just a thought. other than that it sounds like a buy but I would be prepared to repalce items such as cooling system to include water pump, thermostat, expansion tank, hoses and belts to be on the safe side. These are the weak areas in the E46 models that will cause you the greatest headaches if left unmaintained. Just my two and a half cents worth...
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 06-17-2011, 08:05 AM   #6
MikeSamteladze
My Ride: BMW M3 E46
Should I always consider so many replacement when I'm buying a used car?
I understand, that I have to check out the belts and oil.
But should I always do some renewal in suspension parts too?
Old 06-17-2011, 09:13 AM   #7
Zchild
Cool
With the E46 the cooling systems are their weakness and most fragile. My cooling system didn't fail until 200K but this forum is replete with horror stories of cooling system failure.
The suspension systems on these vehicles generally begins to show age, wear and tear around 100K. I did a suspension system over-haul at 110K.
