Old 06-24-2011, 04:12 AM   #21
shifty1982
My Ride: e46 323ci
got car back after tune will put up data sheet in the next couple of days but i gt max 157.1 kw at the wheels which means 210 rwhp
shifty1982 is offline   Reply With Quote
Old 06-24-2011, 05:14 PM   #22
secono330ci
My Ride: 04' 330ci/15' A3 TDI
That's awesome! Please post up the dyno sheet, I'm anxious to see it.
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 06-27-2011, 09:51 AM   #23
secono330ci
Waiting...
Old 06-27-2011, 11:25 AM   #24
Iceman00
Banned User
My Ride: E90 6MT
Waiting as well.
I predict two possible scenarios
One with the plateau like I posted above
Or
Power rising until fuel cutoff.
Either way, that is a lot of cam for a stock manifold/head.
Old 06-27-2011, 11:31 AM   #25
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Really nice, man. Can't wait to see the curve!
Old 06-27-2011, 11:50 AM   #26
secono330ci
Originally Posted by Iceman00 View Post
Waiting as well.
Or
What would the second scenario look like?
Old 06-28-2011, 03:23 AM   #27
shifty1982
My Ride: e46 323ci
there u go guys
Old 06-28-2011, 10:26 AM   #28
secono330ci
Translates to 219.45 whp (dynojet). Wow!
Old 06-28-2011, 10:32 AM   #29
shifty1982
My Ride: e46 323ci
Are u talking about my dyno data mate ??
Old 06-28-2011, 10:42 AM   #30
Iceman00
Banned User
My Ride: E90 6MT
209whp, but I can't tell what the torque is.
Old 06-28-2011, 10:45 AM   #31
shifty1982
My Ride: e46 323ci
Sorry I only have a camera to copy it if u like I can take a close up of the torque bit and it's 210.45 whp I used a converter
Old 06-28-2011, 12:15 PM   #32
secono330ci
Edit:
Yes. I usually refer to a dynojet since that's what I'm most familiar with. So 210.58whp on a dyno dynamics dyno would read 220.05whp on a dynojet.
Old 06-28-2011, 12:18 PM   #33
shifty1982
My Ride: e46 323ci
Yes. I usually refer to a dynojet since that's what I'm most familiar with. So 209whp on a dyno dynamics dyno would read about 218whp on a dynojet.
fair enough either way its a big improvment from stock i also found out today that my injecters are leaking a bit so i should get a bit more once i fix that
Old 06-28-2011, 12:29 PM   #34
secono330ci
Definitely. I edited my post, I'm getting all sorts of numbers from conversion websites.
Old 06-28-2011, 01:39 PM   #35
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
........... and it's 210.45 whp I used a converter
I dyno everything on a DynoDynamics dyno. I've been told by multiple sources that the minimum up conversion number is 10% when going from DynoDynamics to Dynojet. 12% may still be more accurate.
210.45 x 10% = 231.495WHP
210.45 x 12% = 235.704WHP
SUMMIT POINT WV 1:24:229 SCCA
Old 06-28-2011, 01:45 PM   #36
aggieE46
Keep it clean
aggieE46's Avatar
Interesting dyno. You have no power dip due to your DISA. Have you had it tuned out?
Old 06-28-2011, 02:10 PM   #37
secono330ci
It depends what model it was. There's the dyno dynamics 1.0 and 1.1
From another website:
If it was "1.0", multiply the dyno result by 1.15.
If it was "1.1", multiply the dyno result by 1.045.
Old 06-28-2011, 02:14 PM   #38
Rob43
Rob43's Avatar
Very good to know. Now I need to find out which one I'm on.
Thanks.
PS. Link to that website.
Old 06-28-2011, 03:32 PM   #39
triggrhaapi
My Ride: 2000 328Ci, E30 S50
Big cams, decent power. Is it Supersprint all the way headers back or is it headers only, muffler only? If I were doing any exhaust work on my car at all, I would be doing 330 stuff all the way back.
BBS LM Reps | H&R Sport | CSL Bumper | Carbon GTR Hood | Carbon CSL Trunklid | BMW Performance Intake
triggrhaapi is offline   Reply With Quote
Old 06-28-2011, 05:30 PM   #40
Iceman00
Banned User
My Ride: E90 6MT
Dyno dynamics shootout mode would be the equivalent to a dynojet numbers.
I can see there is a dip at the beginning of the graph, probably the disa transition. And I'd imagine this is with a full supersprint exhaust system headers to muffler. More power could probably be gained with a better intake manifold (of course) and intake setup (vs a stock box if he's running one)
Overall, great job. The power pulls towards redline and levels right off, pretty much in the a combination of both scenarios I predicted.
