Old 02-10-2012, 10:58 AM   #101
shifty1982
My Ride: e46 323ci
Originally Posted by moranor View Post
btw what max RPM you running? the graph shows speed not rpm im trying to work out where the dip is...
Standard redline 7500 or what ever
shifty1982 is offline   Reply With Quote
Old 02-10-2012, 11:54 AM   #102
moranor
My Ride: 323i
so then the dip is at about 3000rpm?
moranor is offline   Reply With Quote
Old 02-10-2012, 12:34 PM   #103
shifty1982
My Ride: e46 323ci
Yea that's just before vanos kicks in and the cams do there job the best it's like hitting boost almost when the power band kicks in
Old 02-10-2012, 12:51 PM   #104
Iceman00
Banned User
My Ride: E90 6MT
Vanos is always on.
Old 02-10-2012, 12:59 PM   #105
moranor
My Ride: 323i
I think im going to do this just need to talk to my local tuners and see what they have to say and how much its going to cost me... so far its looking good
I think these would be even better on a 3l because they would not suffer as much because the dip should be at lower rpm...
Old 02-10-2012, 04:22 PM   #106
Bmw_fever
My Ride: 01' 325i ZSP ZCW
from what i have seen 330i cams make very little difference... if you can get them for nothing and can fit them yourself it might be worth it if not rather get proper performance cams...
Performance cams are expensive, you can get a set of ZHP cams for about 400$... I'm pretty sure they would make about 5-10 HP.
Bmw_fever is offline   Reply With Quote
Old 02-10-2012, 06:14 PM   #107
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
I didn't pay much more than that for my Schricks.
Old 02-10-2012, 07:13 PM   #108
shifty1982
My Ride: e46 323ci
Originally Posted by Iceman00 View Post
Vanos is always on.
Sorry when vanos advances is that better
Old 02-10-2012, 07:15 PM   #109
shifty1982
My Ride: e46 323ci
I wish I did it to a 3.0l now so yes u are right much more toque than 2.5l when this motor dies I will be getting 3.0l motor
Old 02-10-2012, 09:44 PM   #110
Bmw_fever
did you get a deal? I thought they were 700.
Old 02-10-2012, 09:53 PM   #111
shifty1982
My Ride: e46 323ci
Mine where 1500 so yeah
Old 02-10-2012, 10:07 PM   #112
aggieE46
Keep it clean
aggieE46's Avatar
Well, used.
Sent from my PC36100 using Bimmer
Old 02-11-2012, 01:18 AM   #113
moranor
My Ride: 323i
i can get copies ground for about $800 locally... the place that will cut me some makes cams for most of the race teams here so they have proven they can do the job well... i wont bother with zhp cams too small a gain for the effort i think...
Old 02-11-2012, 01:21 AM   #114
moranor
My Ride: 323i
@ shifty thats my plan too... if i need a rebuild im going to swap some 3l goodness in there
Old 02-20-2012, 02:37 AM   #115
moranor
My Ride: 323i
Can someone convert that torque number for me?
sorry Iceman00 i was wrong about the torque figure its not as simple as i thought you cant just take the N figure and drop the last 0 to get Nm they completely different units
I have found a formula that works using the power figure to calculate torque
Torque [Nm] = 9549 x Power [kW] / Revs [rpm]
so using the graph where peak torque is at 4000rpm
Torque [Nm] = (9549 x 127 [kW]) / 4000 [rpm]
Torque [Nm] = 303Nm at the wheels
so then it has 223ftlb at the wheels
Old 02-20-2012, 01:43 PM   #116
e60fan
My Ride: 525i
so is it 303/0.85=~356Nm at the flywheel? quite impressive 245Nm in stock...
e60fan is offline   Reply With Quote
Old 02-20-2012, 02:00 PM   #117
moranor
My Ride: 323i
what % you using for loss... if i use 15% i get 348Nm
Old 02-20-2012, 02:27 PM   #118
323I00
My Ride: E46 323I
So cams are worth It on the 323 series from what Im reading.
I wonder how that would play with Ebay headers ,full catback exhaust (no cats) ,cai ,Tms pulleys, and a Shark Injector.
Functional justification... true. But girls dropping their panties counts for something
BBK on non-supercharged-non-m..... because chasecar
323I00 is offline   Reply With Quote
Old 02-20-2012, 06:26 PM   #119
Iceman00
Banned User
My Ride: E90 6MT
A little, but I think you mean *retards cam timing, As in, it keeps the valves closed a bit longer.
I could be wrong though....?
Old 02-20-2012, 06:26 PM   #120
Iceman00
Banned User
My Ride: E90 6MT
Thanks man, and that number is crazy.
