Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Complete Cars - Private
Old 06-19-2011, 07:07 PM   #1
CTD EXP
My Ride: 07 Avalanche
FS/FT 850i V-12/6-speed (ATL)
I am selling my 1991 850i V-12/6speed. Asking price is at 14,500.
There were only 7,232 of the E31 cars brought into the USA, only 4,194 were V-12’s and only 847 were 6 speeds. There are lots of details and good information on 8coupe.com and other sites, so I will spare the model details.
I hate to sell it but my wife was in a wreck and I need to get her a new/newer car. Clean GA Title in my name, Carfax available from when I bought the car, no changes in the history. There is a very complete and extensive service history available on the car. The PO put in a new stereo MB Quarts speakers and Infinity powered sub, JVC HD head unit. Windows are tinted. Currently has a set of BBS by ASA 17” wheels with Goodyear F1 on steer and Michelin Pilot A/S on drive. I have a set of ASA 19’s with General tires for an extra 700 dollars. The MID was just rebuilt and work with no dead pixels.
Serial Number WBAEG131XMCB42274
Mileage 118,xxx
The Good,
Car has just had extensive engine head work completed but a reputable local BMW shop. The heads were removed and a complete rework of the heads were completed (New guides, seals valve job etc.). The engine was completely resealed with all new gaskets, New head bolts, all new motor/trans mounts. New rubber though out ( all power steering hoses, radiator hoses, fuel hoses, Injector O-rings, Vacuum hoses PCV etc…) A new clutch was installed as well as rebuilding the shifter, new water pump, new throttle body etc… 2 new interstate battery’s Lots and lots of work was done and is still under warrantee. This was about 10K in work receipts included.
Other work that was just completed,
4/10 Control arm bushing’s replaced, new spark plug coils
4/09 New Fan clutch
7/07 new radiator
2005 complete re-spray with original color, all weather stripping replaced.
The Bad,
Intermediates check engine light. Code 1222, which could be a O2 sensor, I have not driven the car much in the last 6 months, The light comes and goes it does not affect the performance of the car.
Car needs to be aligned, when the shop pulled the engine they dropped the cradle, and that threw of the steering wheel, it is just off center.
AC does not have a charge; It would not pull a vacuum after they reinstalled the engine, so I did my part to save the environment. I was told it was just a slow leak, needs a seal or something. I was going to fix it later.
I also will be selling my other 1991 850i that you see in the background for about 7.5K, ask for details if you are interested.
More pictures can be found http://s1210.photobucket.com/albums/cc417/matttharp/
Might be interested in a trade for a E46 330/M3 convertible with manual trans.
ID:	406825   Click image for larger version
ID:	406826   Click image for larger version
ID:	406827   Click image for larger version
ID:	406829   Click image for larger version
ID:	406830   Click image for larger version
ID:	406831   Click image for larger version
ID:	406833   Click image for larger version
ID:	406834   Click image for larger version
ID:	406835   Click image for larger version
ID:	406837   Click image for larger version
ID:	406838   Click image for larger version
ID:	406839   Click image for larger version
ID:	406841   Click image for larger version
CTD EXP is offline   Reply With Quote
Old 06-20-2011, 03:06 PM   #2
E46<3
My Ride: M
V12 Bump. GLWS
Do you listen to House?
Have a listen to my SoundCloud
https://soundcloud.com/bryanisaac
E46<3 is offline   Reply With Quote
Old 06-20-2011, 04:27 PM   #3
toocontray91
My Ride: 02 duramax
V12 6 speed! Whats top end on this sexy little beast
toocontray91 is offline   Reply With Quote
Old 06-20-2011, 04:56 PM   #4
CTD EXP
Top speed is ~186 roughly. Neat feature on the car is at 110 MPH or 120 MPH (I forget) if you have the windows down the automatically roll up. I am a pretty slow driver, so I hardly ever get into sixth gear.
Here is some more details about the 8 in general
http://www.topspeed.com/cars/bmw/198...s-ar16405.html
Thanks for the bump
