Old 06-19-2011, 09:38 PM   #1
FunPoliceSam
My Ride: 2001 325i
Clunking noise in reverse/drive
I am getting a clunking noise when I put my gears in reverse. Also getting the same noise outta reverse and into drive. Sounds like it comes from below the car.
I got a STEP with 173k miles. Is my clutch dieing?
I WANT TO CRY & LAUGH AT THE SAME TIME
Originally Posted by nikkei325i View Post
Have any of you heard of "sloming"? Supposedly, high school students are sticking leeches to themselves in exchange for some kind of high. Since when did this become the new thing? What happened to just kicking back with a group of your close friends and smoking a joint?
FunPoliceSam is offline   Reply With Quote
Old 06-19-2011, 09:52 PM   #2
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
guibo maybe
http://www.pelicanparts.com/BMW/tech.../E36-Guibo.htm
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 06-19-2011, 11:45 PM   #3
Eric Giles
My Ride: 2004 330i ZHP
Send a message via AIM to Eric Giles Send a message via MSN to Eric Giles
Well, obviously since you have an automatic you don't have a clutch-so that's not the problem. It's possible that the flex disc (also, but incorrectly, referred to as the guibo) might be the issue if the sound seems to come from directly under the shifter area. If you are hearing the noise coming more from the rear of the car, then it's more likely the differential bushings-and most likely its the rear diff bushing. My rear differential bushing is worn, and when I put the car into reverse I can hear the clunk. It doesn't clunk when I put it into drive.
Eric Giles
'04 330i ZHP
There are few things more expensive than a cheap BMW...
Eric Giles is offline   Reply With Quote
Old 06-20-2011, 12:03 AM   #4
computerwhiz1
My Ride: 2000 323i Sedan
I have had and still am dealing with a problem similar to this. Probably the rear differential bushings are a good place to start. If possible get the car off the ground and look under it while someone is shifting gears, when I did this you could clearly see the rear diff moving around. While rear diff bushings helped my problem I still get a very metallic clank (instead of the clunk which was fixed by the bushings). I am still trying to fix this but I think it has something to do with the flex disc or some drive shaft support bearing (or something like that). I took a video of the sound that mine is making, does it sound like this (from outside the car)?
computerwhiz1 is offline   Reply With Quote
Old 06-20-2011, 01:15 AM   #5
FunPoliceSam
My Ride: 2001 325i
yea i dont know why i said clutch lol, i was reading another thread with clutch issues and its like 100 degrees here in CA and my AC broke.
yea it doesnt sound like that video, definately a stronger clunk.
Old 06-20-2011, 01:22 AM   #6
computerwhiz1
I would say differential bushings then. Does it clunk when shifting gears while driving or just when shifting into gear while stopped?
Old 06-20-2011, 06:48 AM   #7
Bimmage01
My Ride: 330ci ZSP, Duramax
I had a clunking when putting it into reverse since the day i bought it. A year later ....no reverse lol
6MT swap FTW
Bimmage01 is offline   Reply With Quote
Old 06-20-2011, 10:16 AM   #8
computerwhiz1
Just for reference so we can relate this to other similar problems, do you guys have GM of ZF transmissions?
Old 06-29-2011, 11:38 PM   #9
Chad44
My Ride: 03' Imola 330i ZHP
set up a camera under your car looking up at the larger bushing on the rear of the differential (about 2.5" diameter) then hold the brake and shift between drive and reverse then review the footage. I had to replace the one on my wife's 99' 323i e46 and it made all the difference in the world... But you can likely see the damage to the bushing if you are getting a loud clunk and the bushing is in fact the culprit...
Here are some photos, in the first one- this is the view in from the driver rear wheel well but you can easily see the bushing from underneath the car. the bushing is about half way up the photo and 1/3 way in from the right side... see the next photos as reference of what you're looking at.
This is a close up of the bushing, you can see the cracks in it... this is on my 03' 330i manual... just starting to feel a bit funny but no clunk yet, the bushing on my wifes car was a lot more obvious with much of the rubber in the center of the bushing actually missing.
Chad44 is offline   Reply With Quote
