Welcome to the E46Fanatics forums. E46Fanatics is the premiere website for BMW 3 series owners around the world with interactive forums, a geographical enthusiast directory, photo galleries, and technical information for BMW enthusiasts. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
#21 |
- Vincent ![]() |
#22 |
Do you have any problems opening and closing the trunk alone w/o disabling the alarm? I have mine connected to the hood pin and when I close the trunk w/o disabling the alarm, the alarm go off. It looks ghetto
#23 | |
fanatical
never tried it, but, i would imagine the alarm will go off unless you hit the unlock button first to dis-arm the alarm before you "pop" the trunk. the shock sensor will for sure pick up the impact of the trunk closing. if you think it looks ghetto, then why do you open it before hitting the unlock button??? opening the trunk alone will not disable the hood pin, so the sensor will still be active... |
#24 |
The trunk button on the key is designed to pop the trunk in just a thouch of a button, not two. That's why I keep forgetting to press unlock and pop the trunk, especially when my hands are full of stuff like grocery bags.
Anyways, someone told me that if I mount the sensor to the tilt sensor, I will be able to disable the sensor everytime I pop the trunk since the tilt sensor is designed to do that. but thanks anyways |
#25 | |
I used the RadioShack taps, yours look much better.
David
#26 | |||
I've been having a nice conversation with DavidM3Blue about this issue of the DEI.
I've installed the DEI to the Tilt Sensor, this way 100% of the OEM functionality of the alarm is retained. I can open the trunk by the keyfob without disconnecting the alarm, and I can disable the tilt, motion and interior sensors by remote control by pressing the arm button twice. The tilt sensor plug has five wires: the black wire with the blue stripe is the (-) trigger (wire #1), the red wire with the black stripe is the power lead (wire #3), the black with the red stripe is the ground (wire #5). Wire identification courtesy of Dirtboy. Use 3M tap connectors for connection of the DEI to the tilt sensor. I attached the DEI to the same structural beam where the tilt sensor is located. All the car is covered from this location. About the diodes: Quote:
#27 |
Technic, Thanks for posting that!! I am sure others will find it helpful. I am going to try all 3 locations... hahaha.
Already have the hood pin one done, trunk is next and then behind the glove box. Where do you get the 3M taps, they seem much better than the RadioShack ones, I was not happy with them.
David
#28 |
fanatical
wow, you guys are really hung up on this trunk thing. scheesh. you know, i don't think i've ever used my trunk button on the key. i just hit the button on the bottom of the trunk lid and poof, it pops open. just for reference, shock sensors don't like to be tied to metal, or something of structure. if you do use it in back, at least tie it to a harness the way it's supposed to be used. you will lose some adjustment at the front of the car however. this is why they are to be mounted in the middle of the vehicle, so the force is = from the front to the rear. i can set mine up so if a bird ****s on it on the front or rear it would prob. set off the alarm, and any where in between. any car audio shop should give you a hand full of 3M taps. the generic ones aren't worth beans.
#29 |
Yeah the RadioShack ones gave me some trouble, but finally worked.
cls1000 -- I am going to do the glove box mount, as I like the idea of having it in the middle.
David
#30 |
fanatical
well, if you really want to be able to shut off the sensor guys, IE-using the tilt sensor, just locate the negative trip of the tilt sensor at the general entrance module instead of the hood pin wire, and all problems should be solved....
#31 |
cls1000-- I was thinking that before, but which wire is it... hahahaha.
BTW... if I can get this information I will post a full DIY with all part numbers that are needed, etc.
David
#32 | |
fanatical
#33 | |
stahlgrau
A DIY would be great! I just got my alarm activated, and as the stealership was going over it I was just standing there thinking to myself how insecure it is.
#34 |
Had a question about this DIY. I originall had the shock sensor installed under the roof area in Black man's DIY
with DEI interface yellow going to ground. Green wire going to general module control unit red wire going to power the tilt sensor was not used. What wire in your DIY under the glovebox is the general module control unit? |
#35 |
Anyone still have pictures of the wires and shock sensor installed behind the glovebox? It's a mess of wires back there.
#36 |
pics please!
#37 |
pics would be nice...
#38 |
Likes Supermodels
My Ride: Psychedelic Machine
#39 |
Fresh pics much appreciated!!!!
#40 |
fanatical
I'm going to be taking my dash apart here shortly to make some minor mods so I'll be sure and take some new pics for everyone...
