Old 08-18-2012, 12:28 AM   #21
littlegti
My Ride: 2002 330ci conv
Thanks very much for the video...exactly what I needed to see how to do this...bit of a heat wave here so important job to get done immediately.
Couple of notes:
You don't need to remove the hinge on the glove box...just remove it all as one unit. It's definitely better that way on my 2002 330Cic because there's wires going between the main glovebox and the door of the glovebox...they don't really come out separately. I think it has to do with locking the glove box to prevent the trunk from opening with the valet key.
Also the screws were not missing on your resistor. When you remove the module infront of the resistor you are actually unscrewing the screws for the resistor as well.
Again...thank you very very much as the Bentley manual explanation was really inadequate. Pictures worth 1000 words...video is priceless.
littlegti is offline   Reply With Quote
Old 12-06-2012, 09:16 AM   #22
Jarchuleta03
My Ride: 2003 325i
awesome
Thanks for the video got it done in about 20 minutes
Jarchuleta03 is offline   Reply With Quote
Old 12-08-2012, 02:52 AM   #23
sellsellsell2000
My Ride: E46 seden
Send a message via AIM to sellsellsell2000
BMW /// 323i
OEM M-Tech II front & rear bumper /// Cluster Ring /// Grimace Fog Lights /// CCFL angel eye
330i Diff /// REMUS Exhaust /// Heat Shield Cold Air Intake
sellsellsell2000 is offline   Reply With Quote
Old 12-09-2012, 07:57 AM   #24
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Thanks!
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 06-07-2013, 09:37 AM   #25
B-Dawg
My Ride: 2010 Cayenne
Just finished swapping mine. This was SO helpful. Particularly the "...this is backbreaking work..." comment in your narrative. It sure is - I was sweating profusely.
One point of note - the first few steps of disassembly can be skipped, the 6 screws holding the glovebox in can be removed first and the entire assembly pulled out in one piece, rather than removing the hinge, the glove box door, then the glove box internals.
I couldn't have tackled this without this DIY. Thanks!!
B-Dawg
2010 Cayenne
2001 330i 5mt sedan (sold)
2008 135i 6mt coupe (sold)
2004 330i zhp sedan (sold)
2004 325i 5mt sedan (sold)
B-Dawg is offline   Reply With Quote
Old 06-09-2013, 12:17 AM   #26
Solidjake
Zero. Leaks.
Solidjake's Avatar
Yup, I think I added a note to the vid on to just skip that step as you said. Thanks again!
Old 10-23-2015, 05:10 PM   #27
mmiller2002
My Ride: '04 330Ci
Thanks for the video!! I have no idea how you did that. I'm in the middle of it right now, down to reaching the FSR. The hardest part so far was removing the damn connector from it. The tab is too darn small man hands. Mine also has no torx screws holding it in. Maybe Hans had instructions to save money by omitting them...
Anyway, the tab that holds it in does not seem to go far enough back to free the FSR. Is it robust enough to take excessive force? I don't know what else to do except break it off and try to find the missing screws at the dealer or HW store...
Thanks for any advice. And again, awesome video effort, appreciate it.
Mike
mmiller2002 is offline   Reply With Quote
Old 01-09-2016, 12:22 PM   #28
veektor
My Ride: 2002 325xi
Thanks for the video, Jake! I was working with Bentley manual, but it advised me to remove the IHKA unit to get the air duct out of the way. With your video I was able to skip that step and just pulled the duct aside. Not the easiest job, but I was able to get the whole thing done in under 2 hours, and that includes the attempt to get at IHKA unit, at least 30 minutes there.
Oo (|||)(|||) oO
veektor is offline   Reply With Quote
Old 01-09-2016, 12:36 PM   #29
Solidjake
Zero. Leaks.
Solidjake's Avatar
Nice!! Glad the video helped you out
Old 01-18-2016, 01:06 PM   #30
Rick4345
My Ride: 01 330CI SGM
I have a Blackberry I would be glad to give up.
Rick4345 is offline   Reply With Quote
Old 01-27-2016, 12:40 PM   #31
TheRiddle
Sofa-king-what
My Ride: M52TUB28-Vert
i remember that when i didi mine i broke a plastic piece from that thing that is in front of the FSR (the one that has a the metal leverage), fixed with tape, but i never understood what that's moving..
any info on that?
TheRiddle is offline   Reply With Quote
Old 03-04-2016, 07:06 PM   #32
Onizukachan
My Ride: `04 M56 Touring
Thank you for this. Will watch it at least 3 times before I attempt mine!
Onizukachan is online now   Reply With Quote
Old 03-07-2016, 11:26 AM   #33
typeflex
My Ride: e46
Damnit, gonna have to do this, well at least Jake posted a video so that I have an idea of how to do it. Thanks
typeflex is offline   Reply With Quote
Old 03-09-2016, 07:25 AM   #34
Solidjake
Zero. Leaks.
Solidjake's Avatar
Let us know how it works out!
blower, final, frs, fsu, motor, resistor, stage
