Old 06-25-2011, 09:04 PM   #1
Low Level
My Ride: '88 M3
Question Cutting through exhaust piping w/ a Dremel...?
I need to cut off my stock muffler's piping to install a BMW Performance muffler --- can a Dremel do the job, or do I need to have an exhaust shop do it?
-AJ
Low Level is offline   Reply With Quote
Old 06-26-2011, 06:44 AM   #2
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
It can be done with a dremel but will be time consuming. If you're looking to DIY, you can use a hack saw or sawzall. The shop will use sawzalls
phamine is offline   Reply With Quote
Old 06-26-2011, 09:05 AM   #3
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Sawzall.
Old 06-26-2011, 10:42 AM   #4
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Not to mention the number of cutoff wheels you use..
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 06-29-2011, 09:26 PM   #5
Low Level
My Ride: '88 M3
Gotcha, thanks.
Do you have to undo and drop the exhaust on a 325i, or is there room to cut through it while it's still on the car?
-AJ
Old 06-29-2011, 09:28 PM   #6
mvrk10256
My Ride: E30 325i
I would drop it, who is going to weld it for you?
Old 06-30-2011, 02:35 AM   #7
deadpass
My Ride: 01 330i
Use the heavy duty cut off wheel and you can do it, will just take a bit.
deadpass is offline   Reply With Quote
Old 07-10-2011, 12:01 PM   #8
RogueStatus37
My Ride: '04 330ci
Op, you are thinking of a cut off wheel, which is not the same as a dremel. A dremel will chew up disks and take a lot of time.
2004 330Ci ZSP 6-Speed
Blackout grills l Smoked Reflectors l CCFL Angel Eyes l Gloss Black Roof Vinyl l BSW Speaker Upgrade l 3.46 Open Diff l BMW Performance SSKl M3 Style Trunk Spoiler
H&R Sport Cup Spring Kit l RHO Tow Hook Plate l Nokya Hyper-yellow Fogs l Stainless Steel Headers l Tuner Slotted Brake Kit l AXXIS/PBR Metal Master Pads l BMW AUX Input Kit
RogueStatus37 is offline   Reply With Quote
Old 07-10-2011, 08:11 PM   #9
Blocked Out
My Ride: Imola 330i M-Sport
OEM BMW Performance exhaust doesnt need to be welded.
It uses clamps, the pipes on the muffler are stretched a bit to fit into stock pipes and be tightened down with the supplied clamps.
If you dont have a sawzall, home depot rents these out. Over here it costs $20/day to rent a sawzall from home depot.
Original BMW Teile ///
IMG_1725
Old 07-10-2011, 08:15 PM   #10
opey
My Ride: 04 M3 coupe
a grinder with a cutting disc will do it, a dremel will take forever
IR/IR 6 speed
opey is offline   Reply With Quote
