Tyre noise? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 06-26-2011, 05:10 AM   #1
paf
My Ride: E46 325xi
Question Tyre noise?
Hello,
I've been experiencing a strange noise lately, somehow like ball bearings noise. I checked the ball bearings, the mechanic told me they are ok. I've checked the rims, ok. Could it be the tyres?
The noise disappeares above 80-90 kmph and accentuates when breaking...
Tyres are 225/45/17, car: 325xiA nFL
Respectfully,
Alexandru-Florentin Popescu
paf is offline   Reply With Quote
Old 06-26-2011, 11:49 AM   #2
svdw
My Ride: 2003 325XI
I had a similar issue. My issue was a bad ball joint. A lot of play in the left front wheel. You might want to try jacking your car up to see if there is any play in any of your wheels.
Sent from my DROIDX using Bimmer App
svdw is offline   Reply With Quote
Old 06-26-2011, 12:12 PM   #3
White_Knuckles
My Ride: 2003 325xi
Tire can be the source. I had a problem with Yokohama S drives that started "singing" at speed. It was obvious as outer and inner tire cupping was identified on all four tires. This occurred with 15K miles on them. Pressure checks and rotation was performed as normal. Replacement tires (Proxes 4) show no indication of cupping at 10K.
Old 06-26-2011, 01:34 PM   #4
paf
My Ride: E46 325xi
@svdw
I guess the mechanic noticed if the wheels were playing when he checked for noise in ball bearings. I will try another service... Thanks for quick reply!
@White_Knuckles
Is there any way to find out for sure if the tyres are making this noise? Thank you
Old 06-26-2011, 03:42 PM   #5
White_Knuckles
My Ride: 2003 325xi
Feel the inner & outer edges of the tyre treads looking for ridges like a saw tooth. Inflate them to 43 PSI. This moves the ride point to the center of the tyre. This is just for testing.
Old 06-26-2011, 06:44 PM   #6
Kubica
My Ride: 2003 325xi
Front wheel bearings make a whooshing sound when they start to fail.
Swap your tires to different corners and see if the noise comes from the same place.
Front axles can cause the symptoms you are describing also.
Have you ever been on the Transfagarasan highway?
Old 06-27-2011, 12:31 PM   #7
paf
My Ride: E46 325xi
I'm searching for a better service, I will keep you posted. Thanks for the replys
Regarding Transfagarasan... sure, it's a dream, why are you asking?
Old 06-27-2011, 12:46 PM   #8
Kubica
My Ride: 2003 325xi
Because it looks like fun and I'm jealous.
Old 06-28-2011, 03:01 AM   #9
paf
My Ride: E46 325xi
Then come to Romania, i'll borrow you my car for a ride
...and mybe you figure out what's the source of this annoying noise
Old 06-28-2011, 11:29 AM   #10
svdw
My Ride: 2003 325XI
Is that the one they drove on Top Gear?
Old 06-28-2011, 11:53 AM   #11
paf
My Ride: E46 325xi
Yup
