Old 06-26-2011, 07:25 PM   #1
tanzi
My Ride: 02' 325i
Turn Signal Not working
My front driver side turn signal and side marker are not working. I dont have bulb out warning either.
I checked the bulbs and they are good.
Ideas?
tanzi is offline   Reply With Quote
Old 06-26-2011, 07:40 PM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I don't think a fuse controls just those two things, so I'd say look at the comb connector between the two, sort of well hidden. If you look through the hole where your turn signal housing is, you'll see it. That's the first connection that I think is common to both of those lights and I believe it's all ground connections. Make sure it's clean and tight.
You might just try to pull up the bottom tabs on both sockets just a bit, so the bulb is held more firmly, clean any corrosion you see on either bulb or in socket...doublecheck, maybe even clean the electrical contacts...plug and unplug a few times.
One guy lost one of his gaskets for an electrical connector recently...if you have, that would explain things really easily.
Work out from the bulb (maybe even break down and buy genuine bmw bulbs...as they are better than most).
Edit: I just realized that when my socket was the problem, I did have a bulb out warning...and also a fast blinking light.
So, one other thing...make sure the rear turn signal is working. If it isn't, then consider the switch itself. Maybe give it some vigorous exercise?
See me in June!
dmax on Facebook
Mangofy your E46!
Old 06-26-2011, 08:23 PM   #3
RSteckhahn
My Ride: '02 M3
Make sure you use your hand signals as to avoid a ticket... the same signals that bicyclists use are acceptable for car use.
RSteckhahn is offline   Reply With Quote
Old 06-27-2011, 04:46 PM   #4
tanzi
My Ride: 02' 325i
my rear turn signal does work so its got to be that bad connection
Old 06-27-2011, 04:55 PM   #5
dmax
dmax's Avatar
Well...hopefully. Just work out one step at a time. You know it's not the switch. You said it's not the bulbs and I believe you (mostly)! Sockets might both be loose or corroded, as could connections...that comb connector for the grounds would be after that, as if not disturbed, I imagine they'd be good for 'almost' ever!
Unless, of course, you've got aftermarket things added on you didn't mention because you thought they weren't related.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 07-03-2011, 06:54 AM   #6
tanzi
My Ride: 02' 325i
Well not that you mention it...... haha
I run both the front turn signal and side marker off of the side marker. I ran two wires from the side marker up to the front corner turn signal.
So this means the problems relates directly to the power going to the side marker since thats the source of power for both lights.
Old 07-04-2011, 11:36 AM   #7
tanzi
My Ride: 02' 325i
where do the wires from the side marker go? I need to follow that power source
Old 07-04-2011, 03:27 PM   #8
dmax
dmax's Avatar
Work back from the light...or get online wiring diagram...don't all lights go to the light control module?
I'm pretty sure it could also be a ground issue, or maybe the way you wired it too. Check the connections you did first...nothing personal!
See me in June!
dmax on Facebook
Mangofy your E46!
Old 07-11-2011, 05:12 PM   #9
tanzi
My Ride: 02' 325i
i re-did all the connections and everything looks good.
Where is the ground for the side marker?
Is the LCM messed up?
Anyway to check?
