Old 06-28-2011, 10:13 PM   #1
TallSkinnyMatt
My Ride: E92 M3 ZCP
Will I need rolled fenders?
I am looking to buy a set of VMR csl reps. 19x8.5 ET35 Fronts and 19x9.5 ET 40-45 rears. Do any of you know if I will rub and if I will need to get my fenders rolled?
TallSkinnyMatt is offline   Reply With Quote
Old 06-28-2011, 10:16 PM   #2
doshu
My Ride: E46 CI
Send a message via AIM to doshu
Its all about offset and how low your car is really. You will probably need some serious rolling if you are planning on going low for the rears..
Then again, If you aint rubbin, you aint dubbing..
doshu is offline   Reply With Quote
Old 06-28-2011, 10:50 PM   #3
Jmanscotch
My Ride: makes my pants tight
Thats iffy territory.
- Any drop on the coupe or plans to?
- Give a concrete number, are the rears ET40 -or- ET45?
- What tire sizes do you plan on running? (aka, normal 265s or are you going to do a 'stretched' look?)
My novice take on it is that you will likely see more chances of rubbing on the inner-fender well than the outside lip, with those rears. Front's are fine.
-Jake
2004 325CI - 2003 3.0 Z4 - 1994 325i - 1967 1602 - 2008 328XI - 2009 135i - 2007 Jeep Wrangler - 2014 *Loading*
Jmanscotch is offline   Reply With Quote
Old 06-28-2011, 10:58 PM   #4
TallSkinnyMatt
My Ride: E92 M3 ZCP
As of right now I have stock sports suspension. I have no plans on dropping it anytime soon. I'm leaning towards the ET45 for the rears. With that set up i'll be running 225/35/19 front tires and 255/30/19 rears. At least thats the plan.
Old 06-28-2011, 11:02 PM   #5
Jmanscotch
Here is my rear setup with 19x9.5 ET 35 - 265/35s.
Rubbadub rub...every small bump. When I was researching mine, I noted another gentlemans here who has the same setup but running an ET 45 and he was running into inner-well rubbing issues. ET 40 with a 255 tire might be spot on or require just a little bit of rolling to make all work nice.
IMG_0109
-Jake
Old 06-28-2011, 11:06 PM   #6
TallSkinnyMatt
My Ride: E92 M3 ZCP
Thanks for the pic. It'll probably be safe to get them rolled either way. Doesn't cost to much. I'll see what happens once I get them installed. Is your car dropped at all?
Old 06-28-2011, 11:23 PM   #7
ginoe46
My Ride: 323i
You will not have to roll your fenders with that offset. But once again if you get beast tires like a 255/35 then yes it will rub.. I have a 20 offset with 225/35 on a ten inch rim. Depends on what style you go with. Stretched tire? Tucking rim? Or just closing the tire gap
Sent from my PC36100 using Bimmer App
ginoe46 is offline   Reply With Quote
Old 06-28-2011, 11:24 PM   #8
ginoe46
My Ride: 323i
I rubbed all my fender paint away. It melted on all four fenders
Old 06-28-2011, 11:24 PM   #9
Jmanscotch
In that picture, I have H&R Sport springs and Koni shocks installed.
I tried going back to my stock sport supsension on the rear to see if it'd help with clearance, but it didn't. I bought some 255's for the rear...still rubbed. Some more negative camber and I would've been good, just didn't feel like messing with it any more (and fender rolling wasn't something I cared to do...northern climate, snow/salts....corrosion).
-Jake
Old 06-28-2011, 11:25 PM   #10
TallSkinnyMatt
My Ride: E92 M3 ZCP
The thing is, already with 19's the ride is gonna be rough. So I wanna have a little rubber to cushion as much of the blow as I can. If I need to roll my fenders in order to handle a 255/35 tire, then I think it'll be worth it.
Old 06-29-2011, 12:24 AM   #11
sedanpowersc
My Ride: 330i 5 speed
Roll them either way, looks sexy
sedanpowersc is offline   Reply With Quote
Old 06-29-2011, 12:56 PM   #12
lab rat
My Ride: '02 330iT
What are you guys talking about?
19x9.5 ET45 on a coupe will fit just fine with 255/30 tire (even with moderate lowering)
Old 06-29-2011, 05:46 PM   #13
ModBargains.com
ModBargains.com's Avatar
My Ride: F82 M4
You are guaranteed to have no rubbing issues with a 19x9.5 et 45 rear. We currently have CSL rep wheels in stock ready to ship out as well!
Alan Wei | Alan@ModBargains.com | (714) 582-3330 ext. 8006
We Specialize In:
BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts | BMW Tail Lights |
BMW Wheels In Stock | BMW Intake Experts
Hours
: Mon - Fri 8:00am-6:00pm / Sat 8:00am - 5:00pm (PST)
Check out our Blog for updates and discounts!
ModBargains.com is offline   Reply With Quote
Old 06-29-2011, 06:12 PM   #14
sedanpowersc
I'd order some if they weren't so damn heavy
Old 06-29-2011, 06:25 PM   #15
info@VMRwheels
My Ride: E46
We can guarantee perfect fitment without rubbing with our 19x9.5 ET45 VB3's with a 265/30/19 rear tire at stock height!
Info @ VMR | Wheels
(714) 442-7916 | sales@velocitymotoring.com | flickr! | Facebook! | Twitter! | Blog!
info@VMRwheels is offline   Reply With Quote
Old 06-29-2011, 06:44 PM   #16
doshu
My Ride: E46 CI
OH YAH?
Well I am sure OP will be more than happy to purchase whichever sponsor gives a better deal!
Old 07-06-2011, 11:51 AM   #17
Stuttgart330
My Ride: 05 330CIC ZHP
Not too sure about that. I just swapped my 19x9.5 ET45 V701's with 265/30/19 from my coupe to my new 330 vert. Not sure why, but my vert is lower than my coupe (both have stock sport suspension) and I rub on my vert now whenever I hit a small bump or corner hard.. Now need to get the rears rolled on my vert or swap wheels back...
2005 330CiC ZHP Hellrot - (mine)
2006 F350 Diesel CC - (Toy Hauler)
2009 528i Spacegrau Metallic - (wifes)
Stuttgart330 is offline   Reply With Quote
csl, fender, rolled, rub, vmr
