///M3 Forum
Old 06-29-2011, 08:33 PM   #1
PimpNmyM3
My Ride: 2001 E46 M3 6spd
Ebay Header Questions
Well Im finally the proud owner of a newly installed set of Ebay Headers to go with my lonesome agency power exhaust.. plus just replaced my clutch after 4 years. Anyways, Car drives great since install, but still breaking in new clutch... now only 1 of the pre-cat sensors and the egt sensor were able to be installed due to location of sensor bungs. The remaining Pre-Cat and Two Post-Cat sensors are temporarily secured off to the side. My question is will only having the one pre-cat sensor installed effect when the car recieves a software upgrade or do all 4 get eliminated anyways during the re-flash? And is there a way (and is it okay to) to unplug the remaining sensors until I get software?
2001 E46 M3 6Spd Manaul
N/A BPU Software Sponsored by Active Autowerke
Streamline Drop-in + Elbow
Ebay Header
Agency Power Exhaust
PimpNmyM3 is offline   Reply With Quote
Old 06-29-2011, 08:37 PM   #2
///Mspired
My Ride: BMW
You want to keep the pre-cat sensors in until you get a tune. It is okay to remove the post-cat sensors and plug them but not the pre-cat sensors.
///Mspired is offline   Reply With Quote
Old 06-29-2011, 10:36 PM   #3
PimpNmyM3
Well there was only room for one of the pre-cat headers to be installed..
Ebay Header
Old 06-30-2011, 05:40 AM   #4
///Mspired
My Ride: BMW
That is not good, I would find a way to make it fit or get the tune asap. I have installed ebay headers on a car before, you have to improvise. See if there is anyway to make room.
Old 06-30-2011, 10:56 AM   #5
PimpNmyM3
Well.. why do you think thats not good? I mean if the other two are out whats the difference if1 of the pre-cats is out as well?
Im going to try to call a friend in a few who is a tech at the local dealer and see what he thinks..
Ebay Header
Old 06-30-2011, 11:42 AM   #6
PimpNmyM3
Okay.. got my answer from my friend who's a tech.. Im going to have to find a way to extend the harness for the remaining pre-cat sensor or weld in a bung closer so that the factory harness reaches..
Ebay Header
Old 06-30-2011, 12:15 PM   #7
Steven747
My Ride: 05 330ci
how much shorter would the new bung be or how much longer would you extend it from the existing bung hole?
Old 06-30-2011, 01:41 PM   #8
PimpNmyM3
I'll have to measure and see how much further I need to extend the harness in order for it to be installed in the existing bung-hole (lol) on the ebay headers..
Ebay Header
Old 06-30-2011, 02:04 PM   #9
Steven747
My Ride: 05 330ci
if your replacing your pre's and you put it too close up will it have premature failure because of more heat? im guessing not because not much heat escapes between those 3 or 4 inches or so. can you put a new hole on the opposite side of the pipe that the current pre's are on?
Old 07-03-2011, 11:42 AM   #10
PimpNmyM3
I'll have to check but I believe so. I think the best way to deal with this issue is drilling a hold and weldinga new bung in so I can install the 02 sensor.
Ebay Header
Old 07-09-2011, 06:19 PM   #11
Bdave
My Ride: M3 HPF Stage 3
Thats the problem with these Ebay headers...the location of the bungs. Most are not in the correct spot. I got lucky with mine. My tech just had to twist a pipe slightly so one sensor would clear the tranny and could be inserted.
In the end I was happy with mine. But I would have been less so if I had to start welding new bung holes.
All the "ceramic" coating flaked off mine. I suggest a professional coating or header paint. I dont know about ceramic from a spray can. Best bet is professionally applied 2 part coating. We have a guy locally that does this kind of work...well.
It may cost more than the headers cost to get them coated, but you know they will last better that way.
Bdave is offline   Reply With Quote
