Old 06-30-2011, 02:50 PM   #1
Whammy
My Ride: ZHP
Fuel Pump Replacement Book Time
Does anyone know what the book time to replace a fuel pump on the E46? I having some issues with my independent mechanic and need to know what a dealership would charge to perform the same work.
Thanks!
Whammy is offline   Reply With Quote
Old 06-30-2011, 03:37 PM   #2
jcns
My Ride: California
DIY, 1.5 hr with hand. 1hr with both hands.
jcns is offline   Reply With Quote
Old 06-30-2011, 03:39 PM   #3
Mark M
My Ride: e30 M3 / e90 335d
It is very easy. I can do it in under 15 minutes and I work in an office all day. Infact I did do it in under 15 min last month when mine failed.
Any mechanic who takes longer than an hour should not be a mechanic!
Mark M is offline   Reply With Quote
Old 06-30-2011, 03:46 PM   #4
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
change out the fuel pump yourself. it only took me 30 mins and I was going SLOW!!!!!!!!!!!!!
Old 06-30-2011, 04:59 PM   #5
Vinnie Vega
My Ride: 0032870Vette70Velle
never realized it was a quick/easy job, I may do this as a preventative this fall.
Vinnie Vega is offline   Reply With Quote
Old 06-30-2011, 05:17 PM   #6
GRIDLOCK
My Ride: E36 / E46
Thanks!
Whammy, PM me the last 7 of your VIN and I'll get you the BMW factory labor time.
Have an EVAP code? Replacing gas cap did not fix? Give me a holler, I can do a smoke test for ya.
GRIDLOCK is offline   Reply With Quote
Old 06-30-2011, 05:22 PM   #7
TxZHP04
My Ride: ESS TS2+ ZHP
Book time for a shop accounts for more than just the time it takes to swap a part....
Old 06-30-2011, 05:37 PM   #8
GRIDLOCK
My Ride: E36 / E46
Truer words have never been spoken.
Old 06-30-2011, 06:25 PM   #9
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Thanks!
Full or empty tank. If it is full fuel has to be taken out or you risk a big spill.
To the person who did it in 15 Min I realy doubt it. Including pulling the ar in replacing the part clean-up and test driving the car. If you can do that in 15 day in day out everytime you are superman
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 06-30-2011, 06:35 PM   #10
jdstrickland
My Ride: '94 325iC & '00 323i
+1 with the girl with the cat. I was going slow and drinking beer, and I did it in under an hour. I don't the book time, but an hour minimum seems right. You can offer to remove the back seat and save the shop a minute.
Old 06-30-2011, 09:54 PM   #11
Whammy
My Ride: ZHP
Seth, it doesn't matter how much fuel is in the tank. The fuel pump is accessible from the bottom right side of the back seat. The tank does not need to be removed.
To all: Luckily car is now repaired and I do not need to know.
Old 06-30-2011, 11:10 PM   #12
jbeurotech
Regional Sponsor
U
Fuel pump is not in the highest point in the tank so it DOES matter...
Seth Thorson
Old 07-01-2011, 07:34 AM   #13
TxZHP04
U
To a shop that takes the utmost care with a customer's car, it matters. You'll probably never convince the average DIY'er though.
Old 07-01-2011, 07:56 AM   #14
jbeurotech
Regional Sponsor
I would assume most shops and peopl would not just pull the pump dumping fuel all over the inside of the car? That would smell for weeks
Seth Thorson
Old 07-01-2011, 08:11 AM   #15
flashmeow
Banned User
yeah but lets be honest here. some shops will claim to "remove the fuel" just to add more time to the labor when they can easily replace the fuel pump without removing the fuel (assuming fuel at right level). this is why I never take my car to the mechanics unless I have to. come on now...mechanics are just like any other business. they are out to make money or maximize their profits.
NOTE: I am not saying this is how you run your company, i am just saying what I wrote above is not that uncommon.
Old 07-01-2011, 08:17 AM   #16
flashmeow
Banned User
Thanks!
30 minutes and let me break it down for you.
1) 5 minutes to remove back seat cover and bottom cover. they just pop out.
2) 15 minutes to bang/twist the fuel pump collar. this collar is what secures the fuel pump to the fuel tank. use brass tool to bang it because brass doesn't spark.
3) 10 minutes to remove the fuel line and fuel pump
30 minutes right there and that is if you are going slow. I replaced mine in 30 mins (removal and installing)
Old 07-01-2011, 08:17 AM   #17
jbeurotech
Regional Sponsor
I agree, However I also am in a shop management group I see 20 shops numbers all over the country and it the same stories TRUST ME no one is getting rich at this. As an avg expenses are very high in this business
Seth Thorson
Old 07-01-2011, 08:44 AM   #18
Custom3
My Ride: HellRot 330CI
This guy knows his stuff
One of the few on here who is always willing to help with much knowledge
Old 07-01-2011, 09:20 AM   #19
g6
My Ride: BMW
op if you made more than:
~$180 for the job, I think i might die.
$160
http://www.autohausaz.com/search/pro...ump%20Assembly
$20
http://www.autohausaz.com/search/pro...0Pump%20Gasket
$0.59
g6 is offline   Reply With Quote
Old 07-01-2011, 10:04 AM   #20
g6
My Ride: BMW
^all oem
diy, fuel pump
