Old 07-01-2011, 12:28 AM   #1
CuzManJ
My Ride: 2001 330Ci Vert
Cracked radiator so time for a overhaul....
My radiator has a small hairline crack in it. I'm getting ready to order the kit from Turner Motorsports with the stewards pump + expansion tank. New belts are going to be ordered too. Is there anything else I might want to order while I'm doing all this?
CuzManJ is offline   Reply With Quote
Old 07-01-2011, 08:34 AM   #2
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
might as well replace your thermostat. do you have a 5sp standard or auto?
Old 07-01-2011, 10:50 AM   #3
CuzManJ
The kit comes with a thermostat. It's a 5sp
Old 07-20-2011, 07:16 PM   #4
CuzManJ
This should keep me busy for a bit
Old 07-21-2011, 05:52 PM   #5
Sansho
My Ride: 2001 325i
Where's the lower thermostat temperature sensor? If you're refreshing everything else, I'd do that too.
Sansho is offline   Reply With Quote
Old 07-21-2011, 09:05 PM   #6
CuzManJ
Good eye! I have two sensors one for the expansion tank and the coolant temp sensor. What I don't have and need are the plugs or the radiator and expansion tank. The expansion tank bleed screw broke when i touched it and the radiator plug has seen better days.
