///M3 Forum
Old 08-09-2014, 12:21 PM   #1
Hockeyguy02
My Ride: E46 m3
Belt, Pulley, Tensioner replacement e46 m3
Hey guys, so I currently own a 01 m3. I brought my car in for a service and they wanted 900$ to do all of the belts, pulleys, and tensioners. Now i have read any basic mechanic can do this so I intend on tackling this with a friend. My question being. Where is the best place to buy all the parts. ECS has a full package that they put together for 199$ vs the factory kit for 500$. Do I really need to replace all the bolts and washers or might as well since I am already replacing the belts? Is there a cheaper place to buy these kits? It would be ideal if I didn't have to ship and it take a while to get here. Any local shops carry these parts?
Would any of you recommend under driving the pulleys? I have read mix opinions.
Thanks guys.
CarbonBlackCinnamon
30% Tint/Black Grilles And Gills/CF Wrapped Trim/MeganRacingExhaust/DepoSmokedCorners
Hockeyguy02 is offline   Reply With Quote
Old 08-10-2014, 02:03 PM   #2
Hockeyguy02
My Ride: E46 m3
noone wants to chime in? Im looking to pull the trigger on a set pretty quick!
CarbonBlackCinnamon
Old 08-10-2014, 02:52 PM   #3
Teslazerok
My Ride: 2003 M3 6SPD
You don't NEED to replace all the bolts/washers, but you might as well. They cost very little and unless you only want to replace the belts, the cost of that package is probably less than buying all the pulleys and belts individually.
Under driving will gain you some performance by sacrificing your accessories. Not something I would do, but some people aren't concerned about their voltage, a/c, etc.
ECS is good to deal with, usually among the best priced and reliable. I'd recommend buying from them.
Originally Posted by svtmike
Your TL is an eminently replaceable mass production inaninimate object that doesn't give a sh*t about you.
Teslazerok is offline   Reply With Quote
Old 08-10-2014, 04:10 PM   #4
Hockeyguy02
My Ride: E46 m3
Thanks for the reply! Nice to see Youre from the great white north as well. As far as ECS products vs genuine BMW products whats your take. There are two kits and the ECS belts and pulleys and tensioners are about 290$ cheaper. What if I went with the Rogue Engineering Under drive belts and used the 199$ ECS package for the rest? Or stay away from anything other than BMW original parts. Cheers,
CarbonBlackCinnamon
Old 08-11-2014, 01:08 AM   #5
Teslazerok
"Genuine BMW" is usually a joke. Next to none of it is manufactured by BMW, they just badge it and sell it for higher profit margins. That said, the cheapest parts aren't always good quality. I don't think this kit is one you should be concerned about the quality though.
If you're doing under drive pulleys, they may change the belt length, so that ECS kit might not work with them.
Old 08-11-2014, 04:47 PM   #6
AutohausAZ-Mike
AutohausAZ-Mike's Avatar
My Ride: BMW E46
Hi,
You don't need to replace all the bolts and washers unless they are physically damaged.
We do carry the parts that you need for the 01 M3.
Here is the link to our site:
AutohausAZ- Belt drive system
Disclaimer: Make sure to check the year and model of the vehicle before placing the order.
Mike Gallo
www.AutohausAZ.com
1.800.240.4620
AutohausAZ Facebook
AutohausAZ-Mike is offline   Reply With Quote
