Got INPa working and got some codes - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 08-10-2014, 11:34 PM   #1
qsilver_za
My Ride: 2002' Imola M3 SMG
Hey Guys,
Got an 2002 E46 M3 and I have noticed some hesitation at part throttle, which to my mind indicates closed-loop issue, I am relatively new to the car however, I ran a code check on the engine and got the following
Error #144 Lambda regulator 1 . I haven't seen any MAF errors, the car is running slightly rough at idle.
Does this point to the pre-cat o2 sensor for banks 1 - 3 needing to be replaced ? Should I check anything else ?
I thought it might have been unmetered air however there is no MAF errors so far.
qsilver_za is offline   Reply With Quote
Old 08-11-2014, 03:47 AM   #2
qsilver_za
So, I did a re-scan today and there weren't any codes yet.
I tried to use carby clean to listen to the engine while spraying over the intake manifold to see if I could hear a change. It's not really the best way I guess, I do have a custom pressure valve from my Forester that I can use to check the intake manifold is holding pressure but I wouldn't be sure if the same would apply to a NA car to a turbo forester ?
I also have a party smoke machine I could hook up somehow is that the same as the engine smoke machines I've seen used to do the same thing ?
Old 08-11-2014, 08:28 AM   #3
DSilk56
My Ride: M-3 Convertible
If you re-set the codes when you first checked, and the problem is in fact the front pre-catalysts (which I am not sure is correct), the code will not trip again until after between 5 and 12 driving cycles.
DSilk56 is offline   Reply With Quote
