Old 07-01-2011, 12:43 PM   #1
oceanfront26
My Ride: 2000 BMW 328I (E46)
Fan blades fail.
Did anybody had a issue in with your fan blades go flying off and braking the radiator, shroud, air intake duct and messing up the hood too?.
Sent from my DROIDX using Bimmer App
oceanfront26 is offline   Reply With Quote
Old 07-01-2011, 12:50 PM   #2
Hector45
My Ride: 2002 OB 330i
I haven't experienced this myself, but it can happen if you have a mechanical fan.
One of two things probably happen: Your water pump bearing has failed catastrophically making the fan spin off center hitting the shroud and tearing itself apart.
Your motor mounts are toast, letting your engine move too much resulting in the fan hit the shroud which then tears itself apart.
Hector45 is offline   Reply With Quote
Old 07-01-2011, 12:57 PM   #3
jdstrickland
My Ride: '94 325iC & '00 323i
+1
If the blades are breaking off, there is some other problem that allows them to strike stuff. One should search out these problems before putting a new fan on, or the blades will come flying out again.
Old 07-01-2011, 01:08 PM   #4
Nervous
My Ride: 01 330CI 6MT ZSP EU3
http://forum.e46fanatics.com/showthread.php?t=850771
Nervous is offline   Reply With Quote
Old 07-01-2011, 01:20 PM   #5
My Ride: Lexus
Very common with E39s. When I drive BMWs with mechanical fan blades, I always replace them as preventative maintenance. Don't forget the fan clutch too
Old 07-01-2011, 03:37 PM   #6
antonmn
My Ride: 02 325Ci
+1
It's such a known weakness that it's a good idea just to change them. The clutch gets weaker with time, at least mine have.
*signature*
antonmn is offline   Reply With Quote
Old 07-01-2011, 03:39 PM   #7
My Ride: Lexus
And another tip: ONLY *only* only buy genuine BMW fan blades. Do not mess with aftermarket brands such as MTC. Horror stories
Old 07-01-2011, 03:54 PM   #8
smolck
My Ride: 2004 ZHP Sedan
Another possible causer is a failed fan clutch. If they fail and lock up, the engine speed and fan speed will match and these plastic fans will blow to pieces much past 3000rpm.
Check out my BMW Blog
http://smolckbmw.blogspot.com/
Check my Youtube channel for DIY's and fun stuff
http://www.youtube.com/user/flipfinish?feature=mhee
smolck is offline   Reply With Quote
Old 07-01-2011, 04:01 PM   #9
oceanfront26
Thank for all the advice, I just found out that it was all do to fan cluch getting stock and blowing the fan blades apart.
Old 07-01-2011, 04:51 PM   #10
SweTurbo
Big Pimpin'
My Ride: 323i -98
Happened to me , i lucked out though and only got a dent in the hood + belts
Old 07-01-2011, 04:57 PM   #11
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Yes, happened TWICE to me..... first time hood with a tiny nick on it and my shroud going of course. Second time it destroyed my radiator. It turned out to be my engine mounts. Had it fixed and I did the electric fan swap. It will NEVER happen again.
Old 07-01-2011, 05:08 PM   #12
Iceman00
Banned User
My Ride: E90 6MT
Happened to me twice. First time took out the radiator, hoses, belts and the grills (hood was open). Second time, it took out just the radiator on my way home. Hood, belts and hoses were ok.
Old 07-01-2011, 05:22 PM   #13
My Ride: Lexus
yep. luck of the draw. where will the blades go this time... whats involved in the electric fan swap? I have a friend with an automatic 330i and we're going to do his cooling soon. might as well swap...
Old 07-01-2011, 05:33 PM   #14
Solidjake
Zero. Leaks.
Solidjake's Avatar
http://e46fanatics.com/forum/showthr...735&highlight=
Old 07-01-2011, 07:31 PM   #15
cvx5832
My Ride: 325Ci, 325Cic, C300
This, plus a stuck clutch that causes the fan to rotate 1:1 with the pump.
cvx5832 is offline   Reply With Quote
Old 07-08-2011, 11:19 AM   #16
oceanfront26
I'm planning to to the swap tomorrow electronic fan blades, my question is where do you plug the fan?
Old 07-08-2011, 11:41 AM   #17
azshorty
My Ride: Hellrot 323CI
at the aux fan connector.
azshorty is offline   Reply With Quote
Old 07-08-2011, 02:20 PM   #18
330Lover_
My Ride: 2001 330i bk/bk step
What year and which model of E46 have mechanical fan blades? Year? Auto, Step or Manual? 323, 328, 325, 330 or M3?
01' 330i, step, bk/bk, moon, xenon, cd, 18x8 ASA AR1, 225/40/18 all around, Koni Yellow shock, Eibach Pro-spring, Axxis brake pads, 20mm rear spacers
330Lover_ is offline   Reply With Quote
Old 07-11-2011, 01:45 PM   #19
oceanfront26
@330lover. I have a 2000 328i thank you for your help.
Old 07-11-2011, 01:52 PM   #20
Solidjake
Zero. Leaks.
Solidjake's Avatar
Autos
