Old 07-02-2011, 04:34 AM   #1
jamesD2
My Ride: bmw 323 coupe
indicator remove
Hi guys can anyone tell me how to remove front indicators on e46 2000 coupe thank you LIVE THE DREAM.
jamesD2 is offline   Reply With Quote
Old 07-02-2011, 06:27 AM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
If you mean the front side flashers, then just pry out with plastic prying tool...according to Bentley...I haven't done it.
On the front side turn signal, next to the headlight:
You'll see some holes in the metal just above it. One of these is oblong.
Stick a flat screwdriver, with blade perpendicular to the sides of the car into this oblong hole. Angle it maybe 10-15 degrees down so it's pointing to your front wheel, but otherwise parallel with the side of the car. There is about a 1" long concave surface in the plastic clip that you'll feel. If you push in the right place, it'll be spongy a little...that's the plastic bending down. Keep pressure on it while gently pushing up on the handle of screwdriver so you slightly push the housing out.
Then pull it out until you can disconnect the plug. Once you get it, look inside to see how it lines up for installation.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 07-02-2011, 11:48 AM   #3
MacFady
My Ride: 330i ZHP
I'm not sure if the old side indicators remove the same as the facelift ones but if you slide them forward towards the front of the car those ones just pop right out. Same motion for installation.
MacFady is offline   Reply With Quote
Old 07-02-2011, 11:55 AM   #4
kpeng
Banned User
My Ride: E46 330 and E30 325
Yes! Live the dream my brother! May you find peace and happiness in all of your endeavors, including removing that indicator!
kpeng is offline   Reply With Quote
