Old 07-02-2011, 09:57 AM   #1
XXRUSIANXX
My Ride: '04 330i, '02 M3
Passing Cat monitor with catless headers.
Has anyone achieved this? I have tried for the past year with no luck.
Please don't respond by saying "o2 spacers worked for me" simply because you have no MIL. This thread is for finding a solution to pass the Cat monitor, spacers simply do not achieve this.
I haven 't tried o2 simulators but for see them setting a "downstream o2 response" code which would prevent the cat monitor from running.
XXRUSIANXX is offline   Reply With Quote
Old 07-02-2011, 10:11 AM   #2
TxZHP04
My Ride: ESS TS2+ ZHP
The only reliable solution other than a retune to disable the post cat sensors is to simulate them with an Innovate LC-1. I think everything you need to know about hooking up an LC-1 can be found here:
http://forum.e46fanatics.com/showthread.php?p=10773758
You are correct that spacers and generic simulators won't solve your problem. I know the LC-1 can be programmed to work successfully with the MS43 DME, I don't recall if anyone has actually done this with an MS45 DME but I think at least one member may have (lkstaack).
Old 07-02-2011, 10:24 AM   #3
XXRUSIANXX
I can't believe I haven't come across that thread. Thanks a lot I will try this.
