Thread Tools Search this Thread Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 07-03-2011, 09:19 PM   #1
zaphe
My Ride: 2002 330I
Looking for dyno chart
Hi all, it's probably been ask a 1000 times but I can't find it and got bored of searching so I thought that maybe one of you guys could send me a dyno chart for Active Autowerke E46 330 Supercharger Kit Level 2 so I can compare it with other supercharge on the market. I'm looking for the torque curves especially. FYI I'm comparing this kit with the ESS M54B30 TS2 series system. This comparaison has been made several time on the forum but I didn't find any "winner" between the two so I guess I'll have to make my own reasearch.
zaphe is offline   Reply With Quote
Old 07-03-2011, 11:15 PM   #2
Noxx
My Ride: has gold wheels/330i
IMO, if you have the money, get the Twin Screw. My rotrex S/C will only built max boost at 7000rpm where the TS would do it at like 2500 rpm lol.
:Mods:
Driving Schools, AA Stage I, H2O Injection, Headers + Magnaflow Cats, TSE3 Muffler,17'' OZ Alleggerita Gold Wheels, Koni FSD + Eibach Springs, Stewart WP, Underdrive PS, EVO III SS, more to come
Noxx is offline   Reply With Quote
Old 07-03-2011, 11:40 PM   #3
R0B
My Ride: zhp sedan
Is't twin screw linear too? I thought they just have a **** ton more torque and the power band is more ridiculous then centrifugal.
Twin screw ftw though...
Merhaba
:Headers: :Header-back Magnaflow Exhuast: :UUC clutch/lightweight flywheel: :AA stage 1 supercharger: :VMR V710:
For sale: 3.46 differential, 18x8.0 style 135/18x8.5 style 135/ 19x8.5 varrstoen 1.1.2
R0B is offline   Reply With Quote
Old 07-04-2011, 08:29 AM   #4
TxZHP04
My Ride: ESS TS2+ ZHP
This is focused on Whipple but applies to the TS in general:
http://www.superchargersonline.com/content.asp?id=20
I include the link as it provides a good graphic highlighting the fundamental difference in boost curves between TS and centri.
Old 07-04-2011, 10:30 AM   #5
McSpeed
My Ride: 2005 ZHP TT Stg 1
^+1
I think by 'linear' SC vendors just mean 'predictable', as opposed to the wild 'kick' of a big turbo* when it finally spools. Either SC type will be linear in the sense that the the gas pedal always does what you expect.
If "powerband" means "the RPM range where the motor feels strong", then:
  • the twinscrewed motor's earlier-RPM full boost development and corresponding flatter torque curve will mean that it just about always feels strong.
  • the centried motor's later-RPM full boost development and corresponding slanted-upward torque curve will mean that it won't feel quite as strong at lower RPMs.
It's open to debate as to which which type is better in a race (which is generally won or lost at high RPMs) but a twinscrewed motor will feel consistently stronger in day to day driving.
*a turbo setup that is right-sized for driveability will be predictable as well (e.g. the TT Turbo). It won't spool quite as low as a TS, but makes a bit more power for the same boost.
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 07-04-2011, 10:36 AM   #6
MaverickM3
My Ride: gets badge
OP needs a Technique Tuning kit. Boost comes in early and Never let's up.
MaverickM3 is offline   Reply With Quote
Old 07-04-2011, 10:52 AM   #7
TxZHP04
As for turbos, the TT tuning kit is a great example of a "right sized" turbo in my opinion. Sure, you can use bigger turbos for more peak power but that comes at the expense of a longer spool time and thus very different power delivery. In terms of ultimate speed, more power is more power... but you do have to keep in mind your primary usage of the car and how you want the power delivered. Frankly, this last statement is key when choosing between any form of FI whether it be turbo, TS, or centri and to a large degree also applies to the sizing of the components in those varied applications. So often people get too wrapped up in peak numbers.
Old 07-04-2011, 11:44 AM   #8
MaverickM3
My Ride: gets badge
^^^ Totally agree. I can't wait to to go stage2 with this turbo. It's going to be absolutely fun!
Old 07-04-2011, 01:34 PM   #9
malina
My Ride: stock ZHP
ESS M54B30 TS2
AA M54B30 C38 Stage 2
AA C38 Stage 2 vs TT stage 1 (overlay I did)
malina is offline   Reply With Quote
Old 07-04-2011, 04:20 PM   #10
zaphe
My Ride: 2002 330I
Originally Posted by malina View Post
ESS M54B30 TS2
Thank you
Old 09-01-2013, 04:43 PM   #11
secono330ci
My Ride: 04' 330ci/15' A3 TDI
Can someone please re-post those graphs? The links don't work. Thanks.
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 09-01-2013, 07:10 PM   #12
BMW_Knight
My Ride: STG2 ZHP,E70 X5(DD)
Send a message via ICQ to BMW_Knight Send a message via AIM to BMW_Knight
Here you go. Thinking about it? I need a silver twin!
http://forum.e46fanatics.com/showthread.php?t=916245
Thanks to: www.getbmwparts.com www.aatuning.com www.toyotires.com
Eurowerkz Mid-Atlantic Regional Director
Join the Eurowerkz Facebook Fan Site : Click Here
Need your car coded with Euro Options? (Remote Windows up, Corner delete, DRL off, etc.) PM Me
BMW_Knight is offline   Reply With Quote
Old 09-18-2013, 01:03 AM   #13
secono330ci
Thanks man. Good numbers. And yeah maybe down the road haha. Probably going to build the engine a while I'm at it.
Old 09-18-2013, 08:34 AM   #14
Viral@ActiveAutowerke
Past Site Sponsor
My Ride: E46 M3
Stage 2
Viral@ActiveAutowerke is offline   Reply With Quote
