Sponsored by The Tire Rack
Old 07-05-2011, 01:39 AM   #1
TallSkinnyMatt
My Ride: 330ci, 135i
19x9.5 ET33 Tire size?
I have 19x9.5 ET33 CSL rear wheels. What is a tire size that will not rub. I am thinking 245/30/19. Let me know what your guys think.
Also, will a 245/35 tire work for the front with a 19x8.5 ET35 wheel without rubbing?
TallSkinnyMatt is offline   Reply With Quote
Old 07-05-2011, 01:42 AM   #2
Dominic.G.
Banned
My Ride: Jetblack 1999 323i
I have 235/35zr19's on the same spec wheels. Check out my progress thread for pics.
Dominic.G. is offline   Reply With Quote
Old 07-05-2011, 01:44 AM   #3
TallSkinnyMatt
And you didn't get any rubbing with those tires?
Old 07-05-2011, 04:17 AM   #4
Iceman00
I screwed up and can't post
My Ride: ghey
245 on a 9.5? That's skinny.
Old 07-05-2011, 08:00 AM   #5
Jmanscotch
My Ride: Hairdressers car
I was running 235/30 19 on the front with no worries...spot no tire size for that width.
I'm not sure on the rear, rubbing wise, but I ran 265/35 19 on that wheel and it fits perfect (aka no stretched look).
-Jake
Jmanscotch is offline   Reply With Quote
Old 07-05-2011, 09:19 AM   #6
G-Hots
My Ride: ///M3 & 328ci & X3
Send a message via AIM to G-Hots Send a message via MSN to G-Hots
you are going to stretch the sh!t out of that tire with 235/35's man.. I feel bad for those tires
G-Hots is offline   Reply With Quote
Old 07-05-2011, 10:06 AM   #7
TallSkinnyMatt
a 265/35 is ideal for the size of the wheel. Did you not have any rubbing issues on yours?
Old 07-05-2011, 11:31 AM   #8
a32axo
My Ride: 2004 bmw 330CI
tires
I got et 35 9.5 rims on the back with 255 30 19 and i am going to rub, im dropped with eibachs. I will suggest running 235 35s in the rear if your dropped. 225 35 in the front.
a32axo is offline   Reply With Quote
Old 07-05-2011, 12:13 PM   #9
VMRWheels
VMRWheels's Avatar
My Ride: 1:25 Scale Enzo
We generally recommend a 265/30/19 with our 19x9.5 ET45s for non-Ms, but in your case you may need to do fender work if you run that size. Having a 255/30/19 will add a bit more clearance, but probably will still require more fender work. Unfortunately a 245/30/19 is somewhat hard to find, and a 245/35/19 is slightly too tall for the car.
Were you looking to leave the fenders untouched?
Kevin @ VMR | Wheels
Tel: 714-442-7916 | Email: kevin.a@velocitymotoring.com
Facebook! | Flickr! | Blog!
Old 07-05-2011, 04:09 PM   #10
TallSkinnyMatt
I do not want to touch the fenders if I don't have to. Will the 245/35 be to tall? I already have toyo tires in that size and they generally have a low sidewall.
Old 07-05-2011, 04:13 PM   #11
TallSkinnyMatt
Also for the fronts I had 245/35 tires and they barely rubbed. Only touched the front fender when i turn the wheel all the way possible to the side. Barely touched. Thinking about moving those tires to the back and getting either 225/35 or 235/35 for the fronts. What do you recommend?
Old 07-05-2011, 08:22 PM   #12
JG!
My Ride: 07'E90 08'E92
My car is lowered on Eibach sportlines. I had 265/30/19 with ET33 in the rear. They're was little rub even with rolled fenders. I'd would go with a 255/30/19 rear and 235/35/19 front
JG! is offline   Reply With Quote
Old 07-06-2011, 12:15 PM   #13
VMRWheels
VMRWheels's Avatar
A lot of people run a 245/35/19 on E46Fanatics because it's a pretty easily obtainable tire size, however it does sit a bit too tall for the car. Generally you can go up or down in sizing as long as it is within 3% of the OE rolling diameter. Those are about 3.42% or so larger than the OE diameter, so it is slightly too tall, which is why we generally do not recommend that sizing.
In any case I'd say a 255/30/19 would be most ideal with some fender work.
Old 07-08-2011, 10:21 PM   #14
TallSkinnyMatt
So if I roll my fenders, and put the 255/30 on, I would have no rubbing? And how about the 265/30? Would I only need rolled fenders?
csl, offset, rub, size, tire
