#41 |
According to the charts, I believe I have 5HP19 (A5S 325Z) being an 01. But have to go under the car to confirm.
#42 |
If you're going to do a drain and fill, why wouldn't you also replace the filter? Sort of like changing your engine oil and leaving the old filter in place.
#43 | |
I am just concerned about opening the perfectly working transmission, as plenty of horror stories of transmission going kaput after the fluid/filter change.
#44 | |
#45 | |
Yeh, understand that, but you know .... show me someone who changed their fluid and filter and had an issue. I'm not saying it doesn't happen, but I wonder if it hasn't become almost a wives tale, so to speak. In the several years on this discussion, I don't recall anyone changing their fluid after 100K and posting that their transmission failed. While wives tales have some basis in reality, they can sometimes get blown out of proportion over time. [end contrarian thought for the day]
#46 |
My Ride: Touring, and others
I had a torque converter failure about 2 1/2 years ago. Took out the front pump when it failed at 58,000 miles. I rebuilt the ZF box myself and used Valvoline Max Life Mercon VI fluid. I now have 75,000 total miles on the car without any problems. I plan to change the fluid and filter again at 80,000 miles. This will put my first change at 22,000 miles. I do not expect any further problems with this issue. The torque converter failure was an oddball occurrence and after talking to many transmission techs, no one had ever seen one do what mine did. The stub that drives the front pump swelled and took out the seal ring, ruining the pump. Everything inside miked standard, even the drive and driven clutches. There was no wear or stress evident on the reverse drum either. My car was built on March 29, 2000, so it already had all the upgrades that were not on the early versions. Go ahead and drain and change the filter. DO NOT FLUSH THE TRANSMISSION EVER!!!!!!!!!
[/SIGPIC]I'm fluent in 3 languages:
English Sarcasm Profanity Last edited by Stickbuilder; 11-28-2012 at 05:38 PM. |
#47 | |
By the way, how can I know what tranny I've got, ZF or GM? I've got a 1999 323i made in march 1999 Best regards Rod |
#48 |
Transmission Oil (To change or Not to change?)
You have a GM transmission. People usually do not flush the tranny because the fluid is too expensive (if you used the original stuff) and not needed.
#49 | |
You can confirm this by the label on the transmission pan. See this for more info.
#50 |
#51 | |
I am afraid of the oil change, I must admit it, although thanks to this place I understand it's the best thing I can do for my tranny. It's not giving ANY trouble at all, Works fine but I know it's never been changed. My 1999 323i has 108K miles and it's all in excellent condition. Last edited by rodster; 05-18-2013 at 09:29 PM. |
| Tags |
| filter, fluid, lucas oil, skipping, transmission |
