Old 07-06-2011, 01:40 AM   #1
moise
My Ride: 330 Ci E46/318is E30
M52B25 stoker kit
I would like to know if I can mount the M52B28tu crankshaft and Connecting rods on a M52B25tu ?
The cylinder head is identical, engines have the same bore, the cam shafts are the same, only the stroke seems to differ.
As far as I know M52B25tu has a compression ratio (10.5) higher than M52B28tu (10.2), resulting a higher compression M52B28tu .....
I already have a M54B30 intake that will be mounted on the engine, so a remap will be done.
And last but not least, if possible, it is worth the effort, costs would be up to half those of a direct swap.
The parts will be second hand....mind the wear.
moise is offline   Reply With Quote
Old 07-06-2011, 10:20 AM   #2
mrshelley
My Ride: 2004 330i
It'll work.
