Are Oil traces on the bottom of the vehicle a sign of a serious leak ? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-07-2011, 10:06 AM   #1
alhayek
My Ride: 2002 325Ci
The oil isn't dripping and I'm not losing oil (not in noticeable amounts anyway). But yesterday I went under the car to replace the fuel filter. I noticed that the ares where the Oil Level sensor is located is a bit greasy.
I know I should replace the gasket of the oil filter housing , its not leaking badly, but I'll replace it anyway. What other possible oil leak sources should I be looking at ? (Valve cover gasket, Vanos oil line ...etc )
alhayek is offline   Reply With Quote
Old 07-07-2011, 10:44 AM   #2
OrientBlau
My Ride: 2003 330i
Brake cleaner and see what materializes.
All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
OrientBlau is offline   Reply With Quote
Old 07-07-2011, 10:54 AM   #3
jdstrickland
My Ride: '94 325iC & '00 323i
Pools of oil are a sign of a serious leak, traces of oil are for any practical purpose, normal. Depending on how large the trace is, ignore it. Whether you elect to ignore it or act against it, there is no rush to do anything. Take your time and formulate the appropriate action plan, acquire the necessary parts, then go at it.
Old 07-07-2011, 12:46 PM   #4
alhayek
My Ride: 2002 325Ci
@OrientBlau. Good advise ! I have an oil change coming up soon, so I will do that , replace t he vanos oil line and the oil filter housing gasket and rubber ring, then see if any oil traces are recreated.
@jdstrickland: I think I will tackle it early before it becomes something serious. Thanks for your time
Old 07-07-2011, 01:51 PM   #5
g6
My Ride: BMW
go to wrench it on 1300 S and 700 W. it is a diy garage for about 12/hr you can get your car up on the lift and go to town on it. either that or my friend manages the holladay jiffy lube and will let you walk down in the bay . let me know if you want to work on them soon. we are doing my brother's e36 trans fluid soon at wrench it so maybe we could make a day out of it.
g6 is offline   Reply With Quote
Old 07-07-2011, 01:53 PM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Clean it up with brake parts cleaner and check a few days later.
Old 07-07-2011, 02:19 PM   #7
alhayek
My Ride: 2002 325Ci
That Wrench it shop is Nice! too bad they don't have one down here in orem-provo cuz there is nothing I hate more than jacking my 325Ci with my low clearance lame Walmart bought hydraulic jack and then squeezing under it while the ants feed on my skin!!!.
I Just replaced the Expansion Tank, Fuel pump, Fuel filter and front control arm bushings ... and I have an OEM alarm system and a DICE Mediabridge to install. So I'm giving myself a break for now and I'll tackle the oil issue early August.
I have an Oil change, serpentine belts and pulleys replacement, oil filter house gasket replacement, vanos oil line replacement and spark plugs replacement to do all at once! I will probably do all that August 10th or so. I'll PM u then and see if u have stuff to do as well.
@Solidjake: I think that's what I'm going to do.
Old 07-11-2011, 02:29 PM   #8
base1er
My Ride: 1999 328i
Need oone of those Wrench It shops here in NYC,...
base1er is offline   Reply With Quote
