Old 07-07-2011, 11:04 PM   #1
ZHud3
My Ride: black 323Ci
Antifreeze
yes i do know how to use the search but it couldn't help me today. so my question is do i HAVE to use genuine bmw coolant or can i any ole coolant from the local autoparts store? i'm flushing my coolant system if that makes any difference thanks
ZHud3 is offline   Reply With Quote
Old 07-07-2011, 11:35 PM   #2
cityjohn
My Ride: 2001 M3
I just bought some at the dealer and was wondering the same thing. Here is some label info that may answer a few questions:
Note: Do not mix any additives or other components into
the coolant. To maintain protection against excessive
silicate precipitation, do not mix with different antifreezes
containing nitrites and/or phosphates.
CONTAINS: Ethylene Glycol (107-21-1), Diethylene
Glycol (111-46-6), Sebacic Acid (111-20-6), Sodium
Hydroxide (1310-73-2), 2-Ethylhexanoic Acid (149-
57-5), Corrosion Inhibitors, Defoamers, Silicates, Dyes
and bittering agent.
cityjohn is offline   Reply With Quote
Old 07-07-2011, 11:41 PM   #3
Jmanscotch
My Ride: makes my pants tight
It is recommended since we have aluminum blocks. If nothing else, make sure you get a product that is designed to be aluminum safe.
-Jake
2004 325CI - 2003 3.0 Z4 - 1994 325i - 1967 1602 - 2008 328XI - 2009 135i - 2007 Jeep Wrangler - 2014 *Loading*
Jmanscotch is offline   Reply With Quote
Old 07-08-2011, 01:30 AM   #4
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
buy cheap....dont worry about what the engineers and testing came up with...what do they know
/_________\
O==[][]==O
Old 07-08-2011, 01:31 AM   #5
330i ZHP
330i ZHP's Avatar
oh yea, and it is safe to give to your pets....but you should drink some first to make certain
/_________\
O==[][]==O
Old 07-08-2011, 01:41 AM   #6
MercForHire
My Ride: M235i 6MT
I just use the cheap brand, Peak Extended Life. Provides 240,000 km or five years of protection when a complete cooling system flush and fill is performed
Old 07-08-2011, 01:48 AM   #7
southpaw
My Ride: E36 M3 and E36 318ti
Prestone + Mountain Dew =
-Brandon
239whp/227wtq @2700lbs
southpaw is offline   Reply With Quote
Old 07-08-2011, 06:41 AM   #8
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Does the caffeine really work on cars? I've read others using Dr. Pepper on batteries, but thought that was from the Phosphoric Acid.
I've got a bottle of Mtn. Dew on my desk; normally I'd think you're just trolling, but I've read hundreds of your posts, buddy, so if this is what you recommend, I'll all over it.
Thanks for the tip! BRB
See me in NYC in May!
Comic Strip Live, May 12, 6 p.m. & Greenwich Village Comedy Club May 20, 6 p.m.
dmax on Facebook
Mangofy your E46!
Old 07-08-2011, 08:38 AM   #9
Rubenk
My Ride: M35A2
You dont *HAVE* to use any certain thing.
You could run good ol hose water in there as long as you dont have any freezing temps.
The issue lies in the metals our particular motor is made of. Ours is aluminium and I think some other metal. Typical coolant might corrode the interior of your engine so eventually it will cause serious problems that would be near impossible to repair.
The cost difference isnt that significant when you think about how long a coolant flush actually lasts, so just go with BMW coolant. IMHO of course...
Rubenk is offline   Reply With Quote
Old 07-08-2011, 09:01 AM   #10
nk_zhp
My Ride: ZHP / E30 M3
I've heard from many reputable BMW mechanics that the BMW's coolant tends to be very gentle on the seals and gaskets. Most coolants sold in stores are safe for aluminum so that's not the issue. I would pay a little extra and get the BMW stuff.
'04 330i ZHP - OEM Clears - ///M Strut bar - CoolantSnitch
nk_zhp is offline   Reply With Quote
Old 07-08-2011, 09:46 AM   #11
dan03833
My Ride: 2001 330xi
I did a bit of research on this topic recently. From what I can tell, Prestone Extended Life (about $18 per gallon) meets the standards of BMW. It does not have; silicates, phosphates and is safe for aluminum radiators. The cost between the BMW stuff and Prestone isn't so great, so I'd rather use the BMW stuff. Just remember to mix it with distilled water
dan03833 is offline   Reply With Quote
Old 07-08-2011, 11:03 AM   #12
TopazBlu02
My Ride: 330CI
Use BMW if you have $20 lying around. Otherwise, using Prestone (any car/any make) is perfectly fine and will save you half.
TopazBlu02 is offline   Reply With Quote
Old 07-08-2011, 12:51 PM   #13
330i ZHP
330i ZHP's Avatar
save half on fluid and spend more on repairs later...KEWL
/_________\
O==[][]==O
Old 07-08-2011, 12:58 PM   #14
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Get OEM coolant
Old 07-08-2011, 12:59 PM   #15
mhs328Ci
My Ride: 2000 328Ci
OEM coolant. Its worth the chump change.
It's the one fluid that's forum recommended to keep OEM. Engine, tranny, diff, then everyone has their preferences.
mhs328Ci is offline   Reply With Quote
Old 07-08-2011, 07:52 PM   #16
ZHud3
Ok I'm gonna get oem. Thanks for the help.(except for the trolls)
Old 07-08-2011, 10:03 PM   #17
330i ZHP
330i ZHP's Avatar
not trolls, just replying to stupid questions with stupid responses...although laced with real info
/_________\
O==[][]==O
Old 07-09-2011, 12:02 AM   #18
southpaw
This.
-Brandon
Old 07-09-2011, 12:06 AM   #19
carcus
My Ride: 2006 BMW M5
Prestone will work just fine
2006 M5 E60, "Lord Vader" Last real NA M series
German Car Fanatic. Colorado ///M Flight member, BMW CCA member.
carcus is offline   Reply With Quote
antifreeze, coolant
