Old 07-08-2011, 10:08 AM   #1
Baltimore328
My Ride: 2000 328i
Exclamation e46 alarm harness missing
Just bought a factory alarm for my 2000 328i and the motion sensor wiring harness in the headliner is not there! It's supposed to be pre wired, as it says in the trunk. Any ideas?? Could the harness have been moved when the dealer repaired the sunroof/sunshade?
(I'm going to check the trunk for the tilt sensor harness later - if that's not there then something's afoot!)
Baltimore328 is offline   Reply With Quote
Old 07-08-2011, 11:20 AM   #2
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
It's there. You need to dig around for it. They didn't leave the wires loose or they might rattle and cause customers to complain so they are sometimes folded back, taped, or secured in other ways.
scottjoh is offline   Reply With Quote
Old 07-08-2011, 11:30 AM   #3
Baltimore328
My Ride: 2000 328i
I can't feel anything up there, but my fingers can only reach so far. I tried using a mirror and pulling down slightly on the headliner but couldn't see any wiring. I wonder where it feeds from - up the passenger side B pillar, from the front and around the sunroof? I can't find any info on how the harnesses are routed.
Old 07-08-2011, 12:01 PM   #4
mikeyh1015
My Ride: Bmw 04' 330ci coupe
its their... Try feeling towards the driver side.
BOXING = LIFE
mikeyh1015 is offline   Reply With Quote
Old 07-09-2011, 10:53 PM   #5
Baltimore328
My Ride: 2000 328i
Bingo! After dismantling half the passenger side of the car, I found it! It was on TOP of the sunroof glass! (Thanks likely to the dealership from when they repaired the sunroof several months ago). Anyway, had to reach in there with nab grabbers and pull it out, then fish it through to where it was supposed to go.
Old 07-09-2011, 11:17 PM   #6
deadpass
My Ride: 01 330i
Good to hear your fished it out, I'm glad mine was right there in plain sight.
deadpass is offline   Reply With Quote
alarm, harness, motion sensor
