Old 07-08-2011, 06:34 PM   #1
SilverBullet330i
My Ride: 2001 Bmw 330i
01' 330i rattle under center console
Hey guys i was just a little concerned about the way my car is responding. It started to happen like 3 days ago. I have a 01' 330i automatic transmission and every time i accelerate faster then usual, between 2nd and 3rd gear theres a big rattle under the center console area. I want to say it the exhaust letting out more then usual cause i canceled the butterfly valve due to it being loose and also rattling. So i wanted to know if you guys could help, thanks in advance!! I think it might be the exhaust or tranny, I'm not sure. Any help?
Current 2007 E90 335i | JB4 G5| BMS DCI | V710 19x8.5, 19x9.5
Sold 2001 330i M Sport|MTech 2|35% Tint|Orion V2|EE LED Tails|6K Fogs|aFe Stage 2 CAI|Tri-Stiched M3 Steering wheel|Koni Yellow w/ Tein Springs|BimmerBrakes SS Headers[/COLOR]
SilverBullet330i is offline   Reply With Quote
Old 01-09-2012, 03:46 PM   #2
gixxerguy
My Ride: 2001 BMW 330i
If you have not fixed this yet, the noise you are hearing is the driveshaft center support bearing. This exact same issue occured on my 01 330i. Here are a few pics of mine when it failed:
http://www.osoknrid.com/pics/IMG_0239_resize.JPG
http://www.osoknrid.com/pics/IMG_0244_resize.JPG
And this is what your driveshaft looks like:
http://www.osoknrid.com/pics/IMG_0248_resize.JPG
BMW driveshafts are "non-servicable" meaning that you can not replace u-joints. However, you can purchase the center support bearing and just replace it after splitting the drive shaft in two (on bolt holds it together). Removing the driveshaft isn't too difficult, just takes time since the whole exhaust system needs to be dropped. Oh, and you will need external torx tool (I can't remember which size) to unbolt the driveshaft from the rear differential. Other than that, it really is pretty easy.
Since I tore mine all apart, I was not going to chance it and I purchased a whole new "referbished" driveshaft with center support bearing from http://driveshaftspecialist.com/Impo...FQ5lhwodV2YG4w
Let me know what you did or how this turns out.
gixxerguy is offline   Reply With Quote
Old 01-10-2012, 07:27 PM   #3
SilverBullet330i
Hey, thanks for the comment but yea that was exactly what happened! I had the whole driveshaft replaced at the stealership but it actually wasn't as much as i thought it was gonna be. I had to replace the whole driveshaft cause i had an indy work on it before and they only switched out the guibo and it was put back wrong so the driveshaft play made the guibo twist up and i could of had a problem with the differential and what not back there!
Old 01-11-2012, 09:14 PM   #4
gixxerguy
Just out of pure curiosity, how much did the stealership set you back for this?
Old 01-12-2012, 12:01 PM   #5
SilverBullet330i
It set me back bout $1200 but if you think about it, the driveshaft alone with the guibo costs $800 and some change. And if labor was give or take $400, it's not bad! Cause it's probably like $100 an hour on labor and 3 or 4 hours sounds about right
330i, center console, exhaust, rattle
