E46 Convertible
Thread Tools Search this Thread Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Old 02-16-2013, 04:56 PM   #21
DTB
My Ride: 325CiC 2005
I replaced the roll over module today and the light on the cluster went out! Here's a couple of pointers for any other DIY'ers... The module is behind the right side rear seat. You need a 10 mm wrench to remove two bolts that hold the seat back in place. And you need a 13mm wrench to remove 4 hex bolts that secure the aluminum cover plate in the back of the seat. The roll over module hides behind that cover plate. And the module is secured by 3 special torx screws with a pin in the center of the torx hex socket. The tamper resistent torx screws require a special tool. I happened to have a folding assortment of those torx-with-a-pin wrenches, but it was barely long enough to reach. The screw in the bottom location is the hardest to see and get out. I recommend getting a longer reach specialty torx wrench for this job. The screws are tight due to loctite installed at the BMW factory. So it takes effort to unscrew them.
Of course you'll want the top down, and ensure the key is OFF, or the roll bars may deploy when you tild the module to remove it. I used blue loctite to reassemble.
After everything was back in place, I turned the key, started the car, and the dash light was off.
Some say I now need to get a code reader to reset the faults and register the new module. I may ask an indy to do that later. But Steven's Creek BMW wants $300 to do that...
Hope this helps...
DTB is offline   Reply With Quote
Old 01-08-2015, 01:09 PM   #22
zainm
My Ride: 320ci
Hi everyone need your help.
i drive e46 320ci 2002 convertible. car battery went dead and once it was replaced roll over protection light came on. i have a hard top on as its winters. roll over bars did not pop out but the light came on. i have checked the fuse and tried disconnection the battery again but no solution.
your help required in this matter.
thank you so much.
zainm is offline   Reply With Quote
