Old 07-10-2011, 10:31 PM   #1
holabr
My Ride: 2001 325xi
Leak in AC system
I have a 2001 325xi that must have a slow leak in the AC system. Last year it was not blowing cold air so I had the system recharged. The shop added dye when they charged it. It worked fine all last summer but appears to have lost some of the charge over the winter since again this year I had to have it charged. The shop checked for leaks with the UV light but couldn't find anything. Their conclusion is that there might be a leak in the evaporater behind the dash. Now that they alerted me to it, I do hear a very faint hiss inside the car when the AC is on. I really don't want to tear the dash apart to replace the evaporater.
The question is... has anyone used an AC stop leak product with any success? I am particularly interested in a product called Red Angel A/C Stop leak. http://www.usasealants.com/products/...k-conditioner/
holabr is offline   Reply With Quote
Old 07-11-2011, 07:37 AM   #2
TxZHP04
My Ride: ESS TS2+ ZHP
My understanding is that stop leak products ultimately end up clogging internal parts of the system that shouldn't be blocked and end up creating more repairs in the long run (regardless of what they advertise). Even though replacing the evap is a big job, better to do it right the first time.
Old 07-11-2011, 07:49 AM   #3
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Also that stop leak stuff DAMAGES our shop equipment. Now because of that stop leak stuff we have had to buy a $1300 tester to check every car before we service the AC.
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 07-11-2011, 09:41 AM   #4
rizwan1377
My Ride: 04 M56,LC 100,RX300
Send a message via AIM to rizwan1377 Send a message via MSN to rizwan1377 Send a message via Yahoo to rizwan1377
Like TxZHP04 mentioned, i agree with him that You shouldn't add stop leak stuff in the system. Try any other shop and if they tell you the same then replace the evaporator.
rizwan1377 is offline   Reply With Quote
Old 07-11-2011, 10:44 AM   #5
hummer
My Ride: 2001 330CI
The proper way to service the AC is to evacuate and vac check the entire system prior to rechaging.
