Old 04-17-2015, 03:56 PM   #1
PaulSChapman
My Ride: 2002 BMW 330 Ci
Cracking sound when coming to stop/start
I am getting a "cracking" kind of noise coming from the front of my car (I think mostly left side, but can't be totally sure) when coming to a stop and hitting the brake pedal somewhat hard. The sound is is not a click noise, but a louder cracking sound. Here are some points:
- Most noticeable at slow speeds and hard braking
- Cracking noise happens when brake is applied, and also happens when releasing the brake and slowly accelerating.
- Cracking sounds also occur when turning (say backing out of a parking spot with foot on brake).
- Sound does NOT occur when applying brakes normally/softly during driving, and also does not happen when the car is not moving (i.e., actuating brakes when stopped makes no noise). The noise seems to be due to some sort of torquing of something and happens when the torque is applied and when released.
I have replaced all of the front brake components (new OEM calipers, Meyle rotors, BMW pads, Mintex pads, etc.) - no impact. I don't think it can be the brakes (especially since it makes no noise when braking at a stop).
Mechanic checked suspension components (control arms, bushings, tie rod, sway bar links, etc.) - all seems to be good. Car has 98,000 miles and suspension is original.
My guess is even though suspension seems fine, there is something loose in the ball joint or other component connected to the wheels causing the sounds, but no ideas where to start.
Someone has had to have been through this before, right? :-)
PaulSChapman is offline   Reply With Quote
Old 04-17-2015, 04:22 PM   #2
e9coupe
My Ride: Old BMW's
Cracking or creaking? Meaning, is it similar to a spring creaking or strut/bearing creaking or popping? Or, if you had AWD does it sound like a CV joint going bad? I'm trying to get a better idea of the sound...
e9coupe is offline   Reply With Quote
Old 04-17-2015, 05:10 PM   #3
PaulSChapman
It doesn't sound like a spring. More like cracking or loud popping noises. I will try to post a video with the sound later.
It is a RWD car, so no CV joints
Old 04-17-2015, 08:58 PM   #4
lszlszx
My Ride: 1.8T, XC70
I would double check all fasteners, like the subframe bolts swaybar and so on.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-18-2015, 12:43 PM   #5
PaulSChapman
Here is a short video where you can hear the sounds. Any ideas?
Thanks Iszlszx - I will check all the bolts and connections. Maybe it is something as simple as a bolt loosening up over time.
Old 04-18-2015, 01:06 PM   #6
swordsman11868
My Ride: 2003 325i
I have had a similar light" cracking" noise from the driver rear corner. Almost sounds like an electrical short in the rear speaker but it occurs even with the stereo off.
I'm lowered on Bilsteins HD shocks and coil overs (PSS 10 I think).
I'm afraid mine might be subframe crack.
Your sound is much louder tho.
HTH.
I'm just here to change the world.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
E46Fanatics inspiration Robolop: http://forum.e46fanatics.com/showthr...87566&page=101
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is offline   Reply With Quote
Old 04-18-2015, 01:10 PM   #7
sam_e787
My Ride: 325ci
Try the support brace..maybe it's loose or too tight.
sam_e787 is offline   Reply With Quote
Old 04-18-2015, 02:14 PM   #8
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Tighten your sway bar links. I had one loose and would make noise on slow turns or bumps.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 11-27-2016, 08:45 PM   #9
PaulSChapman
Problem finally solved - the sound was coming from the front reinforcement plate rubbing against the left control arm bushing housing. At some point, the plate got bent causing it to rub against the bushing housing. After bending it out with a long crow bar, the noise was gone.
Old 05-20-2017, 01:47 AM   #10
rodburgundy
My Ride: 2002 BMW 330ci Vert
Would you happen to have a picture of that? mine is doing the same thing and I'm worried it might be the DISA valve, not entirely sure though.
rodburgundy is offline   Reply With Quote
Old 05-20-2017, 04:40 AM   #11
cvx5832
My Ride: 325Ci, 325Cic, C300
New E46 underside
cvx5832 is offline   Reply With Quote
Old 05-20-2017, 04:48 AM   #12
rodburgundy
Hahaha yea I figured that's what it was going to be.. Let's hope that is the issue and not some disa valve again.. Appreciate the reply,
brakes, cracking front suspension
