Still Suffering from hesitation/bucking even after VANOS seals? Look Inside! - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 111 votes, 4.79 average. Display Modes
Old 07-20-2011, 09:28 PM   #21
new//M3fan
My Ride: 77' 924 87' E30
Originally Posted by Optio View Post
I was skeptical too, but it does work and brings back the engine to its original state.
I believe that the issue is this..........
The contact width are set to the high side of the spec. The signal that is traveling across these contacts is quite weak. In other words, the current draw is very small. The device of interest, is not receiving the full signal strength from the PCM. Hence the sluggish performance of the VANOS. The best analogy that I can think of: Measuring the resistance of a conductor with a DMM. You will obtain one value when gently touching the conductor with the leads and a different reading when you press hard.
GREAT JOB OP on the find
Exactly! pretty much sums it up. It would also not hurt to clean the OEM grounding strap contact areas. and perhaps add additional ground wires.
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 07-21-2011, 08:55 PM   #22
brian2305
My Ride: 03 330i zhp
No difference on mine maybe takes a few days great when car isn't warmed up though.
brian2305 is offline   Reply With Quote
Old 07-26-2011, 09:29 PM   #23
TxZHP04
My Ride: ESS TS2+ ZHP
Just a word of caution to those attempting to snug up the contacts: if you snug them up too much, the male pins in the solenoids will actually push the female pins out the back of the connector such that there is no connection at all. Result: SES with P0010 and P0013 codes.
Old 07-26-2011, 10:51 PM   #24
jpbutler1983
My Ride: 2001 325Ci
What an amazing find. I haven't done it yet but I'm excited about it. I had contemplate getting a vanos seal kit (which I will still do), but I'm definitely going to try this first. Thanks man. Awesome find and thanks for sharing.
jpbutler1983 is offline   Reply With Quote
Old 07-27-2011, 12:02 AM   #25
TX78666
My Ride: 330i ZHP, N55 135i
Add me to the list, I think.
I haven't experienced what I would call low-end power loss, but I've noticed a "bump" around 3,000 RPM, where things would get suddenly stronger, so I suspected something was going wrong on the low end, just not bad enough to notice, without the abrupt feeling transition.
I snugged up the connectors on the intake side (couldn't immediately spot the exhaust connector, so I thought I'd try the intake connector and see if it made any difference), and things feel much smoother as the engine revs from low RPM to high. No more "bump." I'll drive it a bit more to confirm, but it was easily repeatable before tonight, and now it is not.
Thanks!
Because... Grocery Getter.
TX78666 is offline   Reply With Quote
Old 08-01-2011, 03:07 AM   #26
TerraPhantm
My Ride: M3 & ZHP
I gotta try this out... maybe tomorrow
Old 08-01-2011, 04:15 AM   #27
mujjuman
My Ride: not an E46
Interesting
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 08-01-2011, 09:34 AM   #28
Drewfus2101
My Ride: N/A
I installed the Besian seals about 10k miles ago, and I still get the 2800 rpm 'hickup'. No codes. Engine is in great shape, so I've always wondered what was going on. I've cleaned the connectors multiple times.
I'll try this tonight and see what happens.
Drewfus2101 is offline   Reply With Quote
Old 08-07-2011, 04:17 PM   #29
TX78666
My car still runs great, AND I just used the same process to clear a P0597 code (thermostat). Great info.
Old 08-07-2011, 05:29 PM   #30
Blocked Out
My Ride: Imola 330i M-Sport
My car has new disa, new beisan seals, all new intake boots, etc everything checks out and everything is new and good. I cleaned the maf and everything that I could clean over the period of 3-5 months. I updated and reflashed the ECU , But I STILL have a little bit of hesitation right before 2800rpm in EVERY gear under load. Its not noticeable unless the car is under load and only at 2800rpm.
I just went to my car and did the procedure described here and went for a test drive. I was about to sh!t myself because the hesitation is GONE and I only drove for like 20min. I only did this procedure on the intake and exhaust Vanos solenoids and there is no more hesitation. there seems to be bit in 6th gear but that just might be the uneven road. Other gears are clear.
I will do this on other connectors later on.
Thank you very much for this info.
Original BMW Teile ///
IMG_1725
Old 08-07-2011, 06:01 PM   #31
new//M3fan
Fixed the code by crimping the connectors?
Old 08-07-2011, 06:02 PM   #32
new//M3fan
That's good to hear!
Old 08-07-2011, 06:33 PM   #33
TX78666
Yep. On the thermostat connector. Thanks for the great idea!
Old 08-07-2011, 06:48 PM   #34
bwallace530
My Ride: 325
I am going to try this when my wife gets back tonight with the car.
Is there any special cleaner that I should buy from the auto parts store or electrical grease that I should get.
bwallace530 is offline   Reply With Quote
Old 08-07-2011, 11:55 PM   #35
bwallace530
My Ride: 325
So i tried it and my MAF conection was fine the VANOS one which I hope was the Vanos one looked fine also I am going to go for a test run real quick and see if it changed anything.
Old 08-08-2011, 12:47 PM   #36
RockLee
My Ride: 99 328i. ZSP, ZPP,
Send a message via Yahoo to RockLee
Going to try this too.
1999 328i Sport Package, Premium Package, 5 speed, Alpine white.
RockLee is offline   Reply With Quote
Old 08-08-2011, 02:44 PM   #37
bwallace530
My Ride: 325
Mine wasn't messing up but I thought I would try it anyway really nothing has changed so I guess it didn't work for me lol. But my pins looked brand new so maybe that is why
Sent from my PC36100 using Bimmer App
Old 08-15-2011, 06:04 PM   #38
Hornung418
My Ride: '04 MB ZHP
Gotta say, George...This has really improved my engine! Thanks for doing it!
Hornung418 is offline   Reply With Quote
Old 08-23-2011, 02:46 PM   #39
new//M3fan
NP, man!
We have to get together again and re-flash your DME again!
Old 08-23-2011, 07:39 PM   #40
bwallace530
My Ride: 325
I need mine flashed
