Thread Tools Search this Thread Rating: Thread Rating: 111 votes, 4.79 average. Display Modes
Old 08-24-2011, 12:32 AM   #41
TxTorqueMade
My Ride: 330i
Send a message via Yahoo to TxTorqueMade
Needs a flash too.
BMW e30 Bling
TxTorqueMade is offline   Reply With Quote
Old 08-25-2011, 07:17 PM   #42
vinndubb
My Ride: 2001 330i
ok, just bought a can of contact cleaner and cleaned all the plugs.
This works guys! Anyone who has been having problems after they have their Vanos seals done, should try this. Heck, do it before. Feels like it helped with the hesitation.
Great idea.
vinndubb is offline   Reply With Quote
Old 08-25-2011, 10:32 PM   #43
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
I might give this a shot
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is offline   Reply With Quote
Old 08-28-2011, 07:32 PM   #44
safly325i
My Ride: 03 BMW 325i
this is a complete newb question but where are all of these connectors located under the hood? Is it possible to get some better pictures of exactly which ones to clean? I'm trying to get rid of the acceleration hesitation I get between 3.5-4k rpms without having to pay someone to do the Vanos seals.
safly325i is offline   Reply With Quote
Old 08-29-2011, 12:17 PM   #45
Lemonsqr
My Ride: 2001 TiAg 330i
Interesting. I am going to have to look into this. What electrical contact cleaner is everyone using? If this is the cure to my coldstart /hesitation problems, then it brings new meaning to "attention to details"!!
Lemonsqr is offline   Reply With Quote
Old 08-29-2011, 01:05 PM   #46
new//M3fan
My Ride: 77' 924 87' E30
I mean no disrespect but if you don't know where these connectors are and are not able to even search or educate yourself; specially when it is discussed briefly above then this DIY is out of your reach.
Also, If your VANOS seals are shot they need to be replaced--This isn't a magical VANOS Seal cure.
Let us know! I Personally didn't use contact cleaner.
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 09-14-2011, 06:28 PM   #47
msbihli
My Ride: 2004 330Ci
Just did the crimp adjustment to mine and it worked as advertised. Amazing. Does that indicate that my vanos wasn't even working? Or does it mean the current wasn't high enough to the solenoid at 3000 RPM? If so, how could a variable current be supplied to the solenoid?
One problem I did have was that I accidentally pushed the female portion into the connector into the backshell while crimping (even when I tried to heed the warnings) and I'd like to fix it. Does anybody know of a way to fix the connector or where replacement connectors can be found? I'd like to not have to replace the entire harness.
Thanks for the awesome tip!
msbihli is offline   Reply With Quote
Old 09-14-2011, 09:08 PM   #48
OrientBlau
My Ride: 2003 330i
This sounds more like a DISA issue. The DISA valve opens at 3750 RPM (fluctuates slightly based upon air temp) and remains closed below, so you get more low-end torque. When the DISA paddle fails, it swings freely in the air stream, in oppositon to the design. This leads to poor low-end torque.
I had the same problem and when I removed the DISA; it was completely shot. It had no tension and moved freely. It takes a few miuntes to remove and replace. Two torx bolts. After I replaced it, the hesistion improved and it now transitions this RPM range more smoothly. However, there is a SIB out which states that this issue may actually need to be serviced by sending out the ECU to have it reflashed. Under hard acceleration, the ECU incorrectly interprets the DISA movement as knock and retards the timing, creating this symptom. A reflash may be a necessary solution for some. Although there is much improvement with the replacement of my DISA performance-wise, I think a possible reflash may be necessary to completely cure this.
Anyway, check into this before you go ahead and take apart your VANOS. It take a few minutes to remove the DISA and inspect it for play.
All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
OrientBlau is offline   Reply With Quote
Old 09-15-2011, 09:29 AM   #49
new//M3fan
You have to be careful not to push the pins out but the fix is easy.
Let the pin go all the way out, take it out and carefully pry up the locking tab and slide it back in and it will stay.
Old 09-15-2011, 10:57 AM   #50
DJ Reminisce
My Ride: Knows Dubstep SUCKS
Great thread OP
Just curious, how long did the entire process take you?
I'm curious if, I am not experiencing the hesitation/bucking if I should even bother? (i.e., don't want to cause more harm than help type situation)
Dinan CAI_Stage II_3.46 Dif
OEM CF Strut Bar_Eibach Sportline_GC Konis
OEM Gloss Grills_H&R Spacers_Clubsport Sills_Painted Splitters
Amber LED Corners/6k HID Fogs/LED Interior_Shadow Emblems
500W_RE Audio_Hertz Components
DJ Reminisce is offline   Reply With Quote
Old 09-15-2011, 11:13 AM   #51
OrientBlau
My Ride: 2003 330i
I use CRCs Quick-Dry contact cleaner and finish it up with some compressed air to ensure its dry.
Old 09-15-2011, 11:18 AM   #52
My Ride: 2016 Lexus
I definitely have to try this to see if it cures my low-RPM surging/bucking. So are you guys closing up the female contacts inside the harness with a small screwdriver or the likes?
Old 09-15-2011, 11:47 AM   #53
new//M3fan
I use these.
http://www.sears.com/craftsman-4-pc-...p-00947090000P
The 90' pick
Old 09-15-2011, 08:25 PM   #54
msbihli
My Ride: 2004 330Ci
newe46fan, you're a stud. Thanks for the tip. Car is running amazing right now thanks to you. Thanks again.
Old 09-16-2011, 08:39 AM   #55
NicB.
My Ride: 2000 BMW 328i
I tried this on all my connectors, no luck. But then again, mine didn't appear to be overly widened or anything like that.
NicB. is offline   Reply With Quote
Old 09-16-2011, 09:27 AM   #56
Courtdale
My Ride: 2001 325i
Subscribed. My 2001 is definitely suffering, will give this a shot this weekend.
Courtdale is offline   Reply With Quote
Old 09-17-2011, 12:01 PM   #57
Courtdale
My Ride: 2001 325i
Can't unplug the solenoid connection, it's on there good. Don't want to force it. Any tricks of the trade to loosen it up??
Old 09-17-2011, 12:34 PM   #58
bwallace530
My Ride: 325
There is a metal clip on the front of the sensor like the one on the MAF push it in and pull up.
Sent from my PC36100 using Bimmer
bwallace530 is offline   Reply With Quote
Old 09-17-2011, 12:57 PM   #59
Courtdale
My Ride: 2001 325i
No, I'm familiar with the clip. I pulled another easier to reach connection and it slid off easily, the VANOS connector isn't budging.
Edit: Very frustrating, just did every electrical connection under the hood, but the only one I can't get is the Vanos exhaust. The one I need. Tried to clean the outside, wiggle etc., nothing.
Old 09-17-2011, 10:56 PM   #60
5ABIVT
My Ride: ss
Someone take a pic to enlighten us to where the vanos i/e are? No im not a nub to DIy I just bought my m3 last week and havent even had the hood up much to know exactly where they are.
5ABIVT is offline   Reply With Quote
