Thread Tools Search this Thread Rating: Thread Rating: 111 votes, 4.79 average. Display Modes
Old 09-20-2011, 06:23 AM   #61
Courtdale
My Ride: 2001 325i
If you locate the vanos (end of the engine block, offset to the left), there is one solenoid clip in the upper right corner, and one in the lower left. The lower left is a @#$%%^ to get to without removing things. And mine is stuck. I have to say though, hitting every other connector under the hood, really seems to have helped. The hesitation and bucking is all but gone as well as the occaisional RPM revving between lower gear shifts. Also, my idle would "bounce" between 600 and 1000 rpms at a stand still. It is now perfectly steady at 600.
Only complaint now is I still feel like there should be more torque/acceleration, for a BMW 6 cyl. I say that, but I don't have any other BMW experience to compare it to, but it seems to lack the pop that it should have. I'm nit picking here though, the ride is smooth for the most part.
Courtdale is offline   Reply With Quote
Old 09-20-2011, 12:03 PM   #62
My Ride: Lexus
I did this a couple days ago. Didn't cure a damn thing when it comes to my acceleration surge/bucking issue. I'm replacing the fuel pump also to see if it cures it.
Old 09-27-2011, 05:43 PM   #63
new//M3fan
My Ride: 77' 924 87' E30
I must stress that you have to do this to EVERY single connector for it to make a comulative difference.
For example,
I had done it to every single connector minus the ICV connector because I was just lazy to take the DISA out.
I went over that connector on the ICV today and it totally changed the way the car felt. Much smoother now and my MPG magically went up as well.
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 09-27-2011, 06:03 PM   #64
froilanr
My Ride: '00 oriental 328i
NICE! i'm becoming a fan of newe46fan! first, the ecu tune now this?!
i'm gonna have to look at these later. i love you man! no ****!
froilanr is offline   Reply With Quote
Old 09-27-2011, 10:44 PM   #65
bwallace530
My Ride: 325
What do you mean every single connection
Sent from my PC36100 using Bimmer
bwallace530 is offline   Reply With Quote
Old 09-28-2011, 09:45 AM   #66
new//M3fan
Every single sensor plug.
I don't remember but does anyone know if the connectors for the fuel injectors have the same internal design as the others?
Or if it's similar to the TB connector.
Old 09-28-2011, 07:24 PM   #67
bwallace530
My Ride: 325
How long does it take to clean and get to them all?
Old 11-02-2011, 03:06 PM   #68
Stinger9
My Ride: '04 330Ci
Have you done your vanos?
Sounds like those symptoms and your car is certainly old enough.
Old 11-02-2011, 06:11 PM   #69
Courtdale
My Ride: 2001 325i
What does that mean?
Old 11-02-2011, 06:32 PM   #70
kwikt
My Ride: 2003 330i
For example,
I agree with this 1000%. I was plagued with codes for years and was throwing parts at this until I saw a thread on squeezing the connectors to make them tighter. Since I did this 2 months ago I have had 0 codes. It almost makes it boring not wanting to fix the car on weekends.
kwikt is offline   Reply With Quote
Old 11-02-2011, 09:26 PM   #71
Stinger9
My Ride: '04 330Ci
All you need to know is here.
http://www.beisansystems.com/
You can use search engines to find out things.
Old 11-02-2011, 10:27 PM   #72
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
i suffered from the exact same symptoms. did this DIY and it didn't help
i changed the plugs which had 98k miles on them and it solved these symptoms.
*not saying this doesn't work, just suggesting to people who have tried this and it didn't help.
Old 11-06-2011, 07:16 PM   #73
new//M3fan
I'm about to do this for all the connectors in my M3 once I get the special tool to remove the intake box and I'll report back.
Old 11-11-2011, 10:32 PM   #74
new//M3fan
UPDATE:
Took the intake off and cleaned the ITB's as well as cleaned and re crimped all connectors
I was experiencing some throttle lag, after the connector clean and crimp the lag is gone. So it's official crimping the connectors nets the same effect as on the non-m's.
The connectors I re-crimped as per the procedure were the:
-Coolant temp sensor
-Oil temp sensor
-ICV
-EDK
-Alternator
-Other oil pressure switch
-MAF
-Lower hose coolant temp sensor
-All the misc on top of the intake manifold and next to the brake booster
-Crank sensor
Old 11-11-2011, 11:04 PM   #75
Hornung418
My Ride: '04 MB ZHP
Bro...you have an M now?
When did that happen??
Hornung418 is offline   Reply With Quote
Old 11-11-2011, 11:10 PM   #76
new//M3fan
Yea, for about a week.
Still have the 330ci for sale.
Old 11-11-2011, 11:18 PM   #77
Hornung418
My Ride: '04 MB ZHP
Damn...bold move, George!
Can't wait to see what you do with it
Old 11-11-2011, 11:43 PM   #78
jaymemaurice
Location: Anchorage Alaska or Kitchener, Ontario, Canada
My Ride: 01 330ci, 03 Passat
Hey guys, in addition to cleaning the contacts, did anyone re-grease the seals of the connector (not the contacts) with white grease?!
Rain Sensor Retrofit: Here
Coupe Headline Replacement: Here
jaymemaurice is offline   Reply With Quote
Old 11-12-2011, 12:24 AM   #79
Stinger9
My Ride: '04 330Ci
To accomplish what?
Have you had a problem taking them apart after years?
Dirt collector.
Old 12-05-2011, 08:14 PM   #80
new//M3fan
UPDATE:
I took out the injector harness on my M3 and noticed they too could benefit from this procedure. So if M3 harness connectors share the same non-m connectors then it would also help!
