Old 07-12-2011, 09:48 PM   #1
BMWpr
My Ride: 2003 325 Ci
Automatic to manuel
I have a 325 coupe 2003 automatic! wanna change the transmission to manual! What things do I need? and how much can it cost me!
Thanks Guys!
BMWpr is offline   Reply With Quote
Old 07-12-2011, 09:53 PM   #2
Lusticles
My Ride: 325Ci
http://forum.e46fanatics.com/showthread.php?t=659314
number one Audi Fan
Lusticles is offline   Reply With Quote
Old 07-12-2011, 09:54 PM   #3
Alex323Ci
My Ride: M3 & 323Ci (sold)
Originally Posted by BMWpr View Post
I have a 325 coupe 2003 automatic! wanna change the transmission to manuel! What things do I need? and how much can it cost me!
Thanks Guys!
in PR there are probably lots of guys named Manuel who can change your transmission. pick the Manuel which is cheapest.
ps you posted same thread twice.
Old 07-13-2011, 02:42 PM   #4
ix3mybmw
My Ride: Orient Blue 330i
Here you go
TYBG
ix3mybmw is offline   Reply With Quote
Old 07-13-2011, 02:43 PM   #5
alpinewhiteon18s
My Ride: 2004 330i
Pedro.
Aurora 60LED Angel Eyes -Clear-corners,sides, and tails -Tint all around -RE ikon exhaust -RE RSMs -BMW performance intake -BMW performance cf strut bar -H&R Cup Kit -TMS sways -Powerflex RTABs -8000k HIDs -Black grills & Trim
alpinewhiteon18s is offline   Reply With Quote
Old 07-13-2011, 03:09 PM   #6
GRIDLOCK
My Ride: E36 / E46
Have an EVAP code? Replacing gas cap did not fix? Give me a holler, I can do a smoke test for ya.
GRIDLOCK is offline   Reply With Quote
Old 07-13-2011, 03:10 PM   #7
Guest021715
Account closed.
manuel est loco, stick with automajic
Old 07-17-2011, 07:22 PM   #8
BMWpr
My bad I meant manual or stick whatever you wanna call it... I think you guys would just interpret what I meant to say! ....
Old 07-17-2011, 08:14 PM   #9
Eliott's-BMW
Eliott's-BMW's Avatar
My Ride: E46 3-Pedal Mafia
If you got the ballz to do it then no problem, otherwise Manuel will not get in your bimmer...
Who has the skills?
e30 project
"May GOD grant you DOUBLE the amount you wish upon me!"
Eliott's-BMW is offline   Reply With Quote
Old 07-18-2011, 10:56 AM   #10
certify
My Ride: 328i 2000
Can 328 be fitted with 6 speed manual?
certify is offline   Reply With Quote
Old 07-18-2011, 11:46 AM   #11
jdstrickland
My Ride: '94 325iC & '00 323i
Thanks Guys!
Personally, I think you should not do this. If you want a manual, then sell the car that has an automatic and buy a car that has a manual. It should be cheaper, and the end result will be superior unless you buy a car that is a pile of junk.
If you sell Car A for $6500 and buy Car B for $6500, then the swap won't cost anything except some paperwork charges. If you drop the trans from Car A and stuff a new trans in its place, then you have the cost of labor plus the cost of the new trans plus the cost of another pedal plus the cost of a new reservior for the brake master cylinder, plus the cost for ...
It could easily cost multiple thousands of dollars to swap out an automatic and put in a manuel (sic). You could sell the car you have and use the thousands of dollars you have in the budget for the swap, and buy a better car that already has the transmission you want. And since the car was actually built with the transmission you want, you won't have any headaches that come from swapping stuff around and trying to make it fit.
