Lowered M3 Convertible Pics (Eibach/Koni) - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 07-13-2011, 01:06 AM   #1
cc///m3
My Ride: 15 535i M Sport
I spent hours on this forum and others trying to figure out the best suspension setup for my needs. Finally got everything installed today and happy to say no rubbing, wheel vibration, or other ill effects. Anyway, here's the setup I just installed:
Eibach Pro Kit Springs
Koni Adjustable Struts/Shocks
Macht Schnell Wheel Spacers (15mm Front, 12mm Rear)
OEM 15mm Rear Spring Pad
General Exclaim 245/275 tires
Height measurements (from center of roundel to fender) are 13.25 all around. I decided against coilovers because I wanted a simple setup, without worrying about adjustments, corner balancing, failing spring perches, etc. I did have to get my wheels balanced to eliminate vibration, and I'll get an alignment after everything settles. Ride quality is as everyone says... much less squat/dive, yet smoother on rough roads. Anyway, hope this is helpful to someone!
15 BMW 535i M-Sport. Glacier Silver / Black Nappa
04 BMW M3 Cabrio. Titanium Silver / Medium Grey SOLD
99 BMW M3 Coupe. Titanium Silver / Dove Grey SOLD
cc///m3 is offline   Reply With Quote
Old 07-13-2011, 01:09 AM   #2
Bimmer4Lyfe
Location: 129 West 81st St. 5A, New York, New York 10024
My Ride: 02 325i
Thats the way it's supposed to look.
Well done!
Bimmer4Lyfe is offline   Reply With Quote
Old 07-14-2011, 12:00 AM   #3
bartman22
My Ride: 2001 LSB M3 Vert
Looks about like mine (same suspension but I also have camber plates and sways). I too have been pretty happy with the ride quality.
Mods: Brakes, suspension, working on speed mods...
bartman22 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-14-2011, 12:30 PM   #4
M3Dux
My Ride: E46 M3 Vert
I have about the same set-up as you minus the Konis and different spacers:
http://www.m3forum.net/m3forum/showthread.php?t=368983
At first, I only installed the front Eibach springs but there was too much of a forward rake and the car did not drive right to me. Then I installed the rear Eibach springs, and that made the rear too low and tucked in the tire. The funny thing is, it sort of looked like stock b/c now the front had bigger fender gap than the rears. Finally, I installed the 15mm rear spring pads and it was just right The thirds a charm!
I'm leaning heavily on Konis after my stocks go out. Did you do the install yourself? It's a pretty easy DIY. Once you get to know one wheel the others are cake. You should drive over bumps slowly and load your car with 4 people to help the settling process.
E46 M3 Vert (Current)
Exterior: Umnitza AE, Hardtop, CSL Trunk, CSL Diffuser.
Interior: CF trim.
Engine/Performance: 4.10s, RE El Diablo, MS Charge Kit, air intake scoops.
Suspensions/Wheels: 19" BBS LM, Eibach Pro-Kit Springs, 15mm rear spring pads, MS 5mm/12mm Spacers.
Summer project: OEM CSL headers, S/CD Rotors, and KWv3.
E90 325i (Retired)
Stock
M3Dux is offline   Reply With Quote
Old 07-15-2011, 02:35 AM   #5
bartman22
You are right the install is pretty easy. I too started with just the H&R springs, then did the Koni's. My experiences with Eibachs have been the same as yours- the rear typically lowers further the the front. It happened on two friends cars and my Mustang. That was the biggest reason I went with the H&R's on the M3.
Old 07-15-2011, 12:31 PM   #6
Teh_M3
My Ride: 2002 M3
That's clean dude.
///M Power
Teh_M3 is offline   Reply With Quote
Old 07-18-2011, 05:50 PM   #7
toj
My Ride: 2005 M3
definitely on my "to do" list...
2005 M3 Gray Manual - [18" Stock running BFGoodrich G-Force KDW, AutoSolutions Ultimate SSK 40%, ZHP Short Shift, TFX Retrofit, Painted Reflectors, PowerFlex FCABS & RTABS, aFe Stage II]
toj is offline   Reply With Quote
Old 07-18-2011, 06:05 PM   #8
Wadia
My Ride: 05 M3 VERT/SMG
Yo, what was the final tab to do that lovely mod? I will be highly interested as too how the car now handles with your latest update??? Please advise Dennis
05 M-3 VERT w/ AFE C/INTAKE w/ elbow, SHARK CHIP, TURNER PULLEY KIT, SMOKED T/LENSES,C/PADDLE SHIFTERS,EIBACH SWAYS,TURNER RTABS/SPACERS, CLEAR BRA W/60/20 AURA UV TINT.
Wadia is offline   Reply With Quote
Old 07-18-2011, 09:30 PM   #9
vv23
My Ride: E46 M3
That drop looks absolutely perfect.
I have konis and eibach's sitting in my garage- should be installing them on my E46 M3 coupe this weekend...I wonder if the coupe needs the 15mm spring pads though..I assume the convertible is heavier in the rear is the reason it sags more.
Can someone chime in?
vv23 is offline   Reply With Quote
Old 07-18-2011, 11:55 PM   #10
supark
My Ride: E60 M5, 69 02
Yes you are absolutely right. Here is my old coupe with eibachs (I now have a vert):
supark is offline   Reply With Quote
Old 07-19-2011, 11:21 PM   #11
vv23
My Ride: E46 M3
That is nice- does that have the 15mm springs pads in the rear?
Is it an even drop like the vert?
Old 07-20-2011, 02:34 PM   #12
supark
All stock spring pads front and rear. It had a little bit of a forward rake as you can see in the pics, but slight enough that you wouldn't really notice it.
The verts drop lower because they're heavier.
Old 07-21-2011, 12:14 PM   #13
vv23
My Ride: E46 M3
Cool
Looks awesome. I'll holdoff on the rear spring pads then.
Thanks for your help
Old 04-25-2013, 04:55 PM   #14
dcdude68
My Ride: 2004 M3 Convertible
Are the wheel spacers necessary or just cosmetic?
dcdude68 is offline   Reply With Quote
Old 04-25-2013, 04:59 PM   #15
taylor192
My Ride: 2003.5 M3
Cosmetic. The struts and springs are the same size as stock, so there will be no clearance issues.
I have the same struts and springs, no spacers.
Old 04-25-2013, 05:15 PM   #16
dcdude68
Cool. I was thinking that as the body came down that there was less tire clearance rather than more, so I couldn't see how there was extra room to "push" the wheels out even if you wanted to.
Hadn't heard of the spring pads before, but that sounds pretty simple.
I'm thinking about just doing PSS10s and calling it a day. They don't seem to list a separate part number for cabs, so I guess you compensate with a more firm initial suspension setting. I have a local suspension guru, and I'm confident that he can make short work of this issue
Old 04-26-2013, 05:07 PM   #17
Dwydz
My Ride: 2003 M3
Looks very nice. I like!
You only live once.
Dwydz is offline   Reply With Quote
Old 04-26-2013, 11:58 PM   #18
illestminimike
My Ride: Project Drama
Cool
Coupes don't need them. Verts always sit like that because the springs people buy are for coupes and the added weight on a vert lowers the rear more than the front.
Old 04-30-2013, 04:11 PM   #19
empower82
My Ride: e46 M3
Good stuff - I am looking for a simple spring/shock setup and don't really care for coilovers at the moment.
empower82 is offline   Reply With Quote
Old 04-30-2013, 06:32 PM   #20
w0w
My Ride: '02 M3 Vert
looks nice! i know where that plaza you took the pic in your sig. hope to see you cruisin around one day
daron
w0w is offline   Reply With Quote
