a/d/s 346is install - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BAVSOUND
Old 05-19-2003, 10:59 PM   #1
dub mon
My Ride: 2000 BMW 328Ci
a/d/s 346is install
I have a 328Ci
- how much work is required to install the a/d/s in the front doors?
- after installing these, will I be able to revert to stock easily?
- will I need to make a mounting plate like whjeffs did?
I'm seeing conflicting information regarding how much work is required:
whjeffs
I put a/d/s/ 346is components in the doors. Pics can be seen on this thread on bimmervibe http://www.bimmervibe.com/phorum/sh...s=&threadid=198
What I ended up buying was the a/d/s/ 346is components. They are the same overall depth & diameter as the factory HK speakers so space is not a problem for them in the panel. I am trying to figure out the best way to mount them though. They don't match up perfectly with the mounting rings of the factory speaker unless I was to file down the frames of the a/d/s/ woofers which I really don't want to do!
I will probably make a mounting plate out of MDF. I really want to focus on making sure they are sealed from front to back. If the resulting midbass is still not what I want I may still cut a hole in the door behind the woofer just so it can use the door as an enclosure and seal the panel to the door with some foam.
I'll post pics of the progress.
http://forum.e46fanatics.com/showthr...ighlight=346is
BMWsoundQ
I have a 330Ci and am running a similar setup. I am running A/D/S 346is in the front doors with only a very small modification to get the mid to fit properly.
SpaceMonkey
Go with a bigger size!
I went with 346is' in the front, and 346im's in the back. They fit with no problems. You'll get better sound out of the 6.5" vs. the 5.25".
I put the speakers in last weekend, and hooked up the amp this weekend. Sounds amazing!
The 346is components fit fine in the stock locations, barely any mods necessary. I was able to put the tweeters in the stock midrange location, just popped right in. I left the stock tweeters in the bracket, but disconnected.
For the woofers, I just pried the stock mounting brackets off the H/K speakers, and put the a/d/s mounting bracket right on top, using some foam as filler. No problems with depth, the doors just popped back on.
I'll post some pictures tomorrow night if people are interested...
dub mon is offline   Reply With Quote
Old 05-20-2003, 05:21 AM   #2
whjeffs
My Ride: 04 Silver Gray 330Ci
Here is a pic of the plate I made to mount them. I'm not sure now if it was really necessary to make the plate fill in the entire area. I may do it differently when the new car comes in.
Jeff
Alpine ics-x7HD
a/d/s 346is
JL Audio 300/2
JL Audio 500/1
(2) Image Dynamics ID8V.3-D4
whjeffs is offline   Reply With Quote
Old 05-20-2003, 05:22 AM   #3
whjeffs
I may just try a simpler plate like this. Although I'd still like to know how this guy got these Focals to fit. Looks like the mounting depth is way too deep.
Name:	focal install.jpg
Jeff
Alpine ics-x7HD
a/d/s 346is
JL Audio 300/2
JL Audio 500/1
Old 05-20-2003, 08:02 PM   #4
dub mon
whjeffs: thanks for replying!
how many hours did it take you to get them in? (including time to build the plates)
Old 05-20-2003, 08:19 PM   #5
whjeffs
I didn't really keep track of how long it took. I didn't do it all at one time. I'd guess about 2 to 3 hours of actual work, including removing and reinstalling the panels, applying the sound dampening sheets to the panel, designing and building the plates, and wiring them up.
Jeff
Alpine ics-x7HD
a/d/s 346is
JL Audio 300/2
JL Audio 500/1
Old 05-21-2003, 10:05 AM   #6
SrCsTc
Banned
My Ride: 00 323Ci
Send a message via AIM to SrCsTc
He had to cut a hole in the door. It's the only way.
Rich
SrCsTc is offline   Reply With Quote
Old 05-21-2003, 01:37 PM   #7
whjeffs
I'm pretty sure that pic of the Focals was on a coupe though. There is a part of the window mechanism that attaches to the door directly behind the speaker on the coupe. I looked into doing it on mine and it doesn't look like it can be done because of this. Sedan doors are different and can be cut out.
Jeff
Alpine ics-x7HD
a/d/s 346is
JL Audio 300/2
JL Audio 500/1
Old 05-21-2003, 02:15 PM   #8
SrCsTc
Banned
My Ride: 00 323Ci
I haven't looked back there yet but there's no other way that the door panels will ever touch the door with that big speaker without cuttin away some metal.
Old 05-26-2003, 12:33 AM   #9
SpaceMonkey
My Ride: 02 330Ci
Send a message via AIM to SpaceMonkey
Re: a/d/s 346is install
Originally posted by dub mon
I have a 328Ci
From what I did, my answers to your questions are:
1. Not much
2. Yes
2. No
I actually pried off the stock mounting plates from the h/k speakers, and then used them with the a/d/s mounting brackets. They're only glued on, and would only take a couple hours for me to return to stock.
I put some pictures up here.
SpaceMonkey is offline   Reply With Quote
Old 05-26-2003, 01:21 AM   #10
Hota
My Ride: 2002 E46 M3
I support SpaceMonkey's answers.
Here's my pic. I did even less work than SpaceMonkey.
I used the old HK mounting ring and just sliped it over the 346is woofer. The tension of the ring bolted to the door holds the a/d/s woofer securely in place.
The fuzz you see is polyfill gone wild!
E46 M3 Ti Silver/Imola
Created 18 June 2002
Hota is offline   Reply With Quote
Old 05-26-2003, 11:12 AM   #11
SrCsTc
Banned
My Ride: 00 323Ci
Re: Re: a/d/s 346is install
1. Not much
2. Yes
2. No
Nice work. How did you mount the amp?
Rich
Old 05-26-2003, 02:07 PM   #12
makonto
Asik Ajee !
My Ride: 328i
how much did u guys buy your ADS 346 ?
makonto is offline   Reply With Quote
Old 05-27-2003, 01:32 AM   #13
Hota
Re: Re: Re: a/d/s 346is install
Rich
Check out my stealth amp install...
http://bimmer.roadfly.org/bmw/forums...3155118&page=2
Old 05-27-2003, 04:31 PM   #14
SST
My Ride: 325i
I love that box idea. Mind if I steal.....errr use it for my sedan?
It looks like it would work with the sedan as well.
Hota,
Where did you get the wiring diagram as to what's what?
Do you have it written down? Is it on the web so I could get a copy?
Thanks.
TT
SST is offline   Reply With Quote
Old 06-03-2003, 12:59 PM   #15
Hota
Originally posted by SST
Hota,
TT
The wiring diagram is located at the bottom of William's HK Upgrade page. The link to William's page is embedded in the beginning of my page:
