01' M3 Convertible Leak - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Convertible
Old 06-29-2013, 10:13 AM   #21
crackerlee
My Ride: 2003 325Ci Conv.
I had the same problem posted by "E46_M3Power" user (7/13/2011). I think I finally fixed it after 2 years of trial and error. First I tried the silicone bead across the front edge where the canvas meets the rubber. That did not stop the leak. Next I tried waterproofing the canvas top with 303 Fabric Guard which you should do annually anyway. That did not work. I checked that the drainage hole and channel that runs down the side of the windshield was not clogged. It wasn't. Here is what I did: I used a 1/4" solid piece of gray foam insulation, the same material that you'd use to wrap hot water pipes (see sample of foam next to a US dime). Insert a piece about 4 inches long into the support frame along side of the roof (in the pic, the end of the foam is seen).
ID:	513596   Click image for larger version
crackerlee is offline   Reply With Quote
Old 06-29-2013, 12:35 PM   #22
TopHydraulicsInc.com
Supporting Vendor
TopHydraulicsInc.com's Avatar
My Ride: German verts
Originally Posted by crackerlee View Post
Here is what I did: I used a 1/4" solid piece of gray foam insulation, the kind you wrap around hot water pipes (see sample of foam next to a US dime). Insert a piece about 4 inches long into the support frame along side of the roof (in the pic, the end of the foam is seen).
Nice - hope that it works long term, and that it will help many others. The round pieces of foam as shown in your picture are often referred to as "caulk saver" in hardware stores, and they are available in various thicknesses.
Klaus
http://www.tophydraulicsinc.com/en/56-bmw-e46
Some BMW E46 hydraulic cylinders, pumps, and valves that we rebuild and upgrade at Top Hydraulics:
54347025593
54347025600
54347025599
54348236956
54348243269
543454347025595 (hydro-unit, sticker p/n is 8234530)
54347025592 (control unit)
54347025598 (improved hoses manufactured at Top Hydraulics)
TopHydraulicsInc.com is offline   Reply With Quote
Old 01-06-2014, 10:09 AM   #23
cdodds2004
My Ride: 330 ci convertible
I have the same problem on my vert here in England its torrential rain at the moment and I cant seem to fix it. it seems to puddle on the rubber section and weep through! tried the silicone and treating the rubbers. the drains are clear. but I just cant put my finger on the cause.
rubbers seem in good condition but water is getting through. im getting that frustrated by it im tempted to change the top seal and the seal on the roof itself! but this is going to cost me a arm and a leg when im sure its a easy fix as its not leaking loads but enough to give my mrs a wet bum!
cdodds2004 is offline   Reply With Quote
Old 05-14-2014, 08:22 AM   #24
LStyleD
My Ride: E46 CI Convert
Solved?
Interesting topic!
LStyleD is offline   Reply With Quote
Old 05-15-2014, 10:09 PM   #25
crackerlee
Actually no. Not solved. While shoving the foam strip into that crevice prevents water from collecting in there, water is still getting past the seal between roof and top of windshield. I cut a piece of 1/16 inch thick foam wrap (the kind you might wrap a fragile item with), placed it near the top of both pillars and closed the roof on it. It's been dry since I did this about 6 months ago but I haven't driven in a heavy rain yet. Obviously not a permanent solution but it might indicate that the rubber is not making strong contact in those areas. Will keep tinkering.
Old 05-16-2014, 02:48 AM   #26
LStyleD
Same issue here, v been trying everything but still, unsuccessful.
Old 05-16-2014, 03:39 AM   #27
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Mine only leaks when it's parked in such a way that water can build up in the top/ windshield junction. I mean really build up, like a thunderstorm. And it's in a nose down attitude.
Weird. I still haven't figured out quite what causes it
Do you ride a sportbike?
Old 05-16-2014, 04:02 AM   #28
LStyleD
Mine only when parked, never when riding, even if it's storming.
Old 09-29-2015, 10:12 AM   #29
pchrist
My Ride: 04' 325Ci
I have the same issue now and it's annoying need to look closer at this to see what I can do! Only when parked
pchrist is offline   Reply With Quote
Old 10-04-2015, 05:26 PM   #30
Steviejay01
Spunkmeister Jay
My Ride: 2000 330Ci
That gummi stuff is awesome i used it on all the old seals on my a4 cab works wonders
Blue Flame Cat Back, Angel Eyes, Dave - F Filter, LED interior, DTM Style 18's
"Knowledge is often mistaken for intelligence. This is like mistaking a cup of milk for a cow"
Steviejay01 is offline   Reply With Quote
Old 10-05-2015, 03:15 PM   #31
SvRe46
My Ride: 02 M3 Vert
Send a message via AIM to SvRe46
I had the same issue. I used black RTV to fix it. Small tear on the rubber seal on the passenger side meeting the top and then both sides needed the plastic center insert sealed up since the glue had cracked. Kind of hard to explain without seeing it. No leaks with our last rain.
SvRe46 is offline   Reply With Quote
