Sponsored by The Tire Rack
Old 07-16-2011, 01:17 PM   #1
Kaph
My Ride: BMW e46 328i
328i wheel fitment question
Hi,
I am willing to buy some new wheels for my 328i, I am just wondering if that setup will fit without rubbing.
Front :
18x8 offset +35
235/35/18
Rear :
18x8 offset +35
245/35/18
Also, if that setup wont rub, is there a possibility I can put some spacers to make the car looks more aggressive? what is the lowest et I can go on a 328i sedan without rubbing?
Thanks for the advise!
Kaph is offline   Reply With Quote
Old 07-17-2011, 09:46 PM   #2
Tater49
My Ride: 04' G35 Coupe
Shouldn't be a problem my setup on my 328i is:
VMR VB3 CSL Hyperblack
Front:
18x8.5 +45
235/40-18
Rear:
18x9.5 +45
255/35-18
No rubbing. Pretty much the widest setup you can get without fender rolling im pretty sure.
2000 328i 5 Spd Black on Black SOLD!
2004 G35 Coupe 6 Spd Gray on Black Current
Daily
FS. JB Racing Lightweight Flywheel (Non-M 6 Speed ONLY) - $450 obo
FS. Spec Stage 3 Clutch Kit (Non-M 6 Speed ONLY) - $400 obo
Tater49 is offline   Reply With Quote
Old 07-18-2011, 07:56 AM   #3
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
Originally Posted by Kaph View Post
Hi,
Front :
18x8 offset +35
235/35/18
Rear :
18x8 offset +35
245/35/18
That would fit but leaves the front tires shorter than the rears. You may want to consider using 225/40R18 up front instead.
Tires
http://www.tirerack.com/a.jsp?a=BN4&...ires/index.jsp
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 07-18-2011, 12:10 PM   #4
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Those should fit without an issue. I'd recommend a 225/40/18 in front though.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 07-18-2011, 02:04 PM   #5
Kaph
All right, I will go with 225/40/18 in front.
Thank you very much for the help!
Old 07-18-2011, 02:09 PM   #6
Snik
Snik's Avatar
My Ride: IR M3 Vert.
id recommend wider rims at both ends.
up another 1/2" or 1" it'll look very normal with those sizes, almost as if its not an upgrade at all.
Do you ride a sportbike?
Old 07-18-2011, 05:14 PM   #7
2003 325i
My Ride: '03 Orient Blue 325i
I'd recommend just using 235/40 tires all around.
Old 02-25-2012, 12:04 PM   #8
xfixkaos
My Ride: 00' 328i
hey i got a question about the fitment also
im looking at running 18x8.5 with a +25 in the front
and either a 18x8.5 in the rear or a 18x10 in the rear with a +25 offset,
will i need spacers if i run the 10 and will it rub? and which tires do u recommend?
for the 8.5 i ws thinking 235/40/18
and the rear prolly somthing like 245/40/18
any pointers as to my fitment skills are retarted lol
thanks guys
xfixkaos is offline   Reply With Quote
Old 02-25-2012, 12:49 PM   #9
Snik
Snik's Avatar
thanks guys
18x8.5 et25 up front can work, but will rub if youre lowered WAAAAYYY low, and id honestly run 225s to be safe.
18x10 ET25 you MUST roll fenders, and you'd best run like 245, or 235s.
You will prolly still rub a lil on hard dips. ET25 is a tight fit on a non M, especially a sedan, but its been done.
Old 02-27-2012, 09:33 AM   #10
xfixkaos
My Ride: 00' 328i
hmm awesome thanks man, nah im not going to be slammed just a ta****l drop was thinking 1.5 or 2 in fron and 1 or 1.5 in rear so i have aslight rake, and yea i dont really wanna deal with rolling the rear fenders, but maybe
might just run the 18x8.5 all around
thanks again for the feedback really appreciate it!
Old 02-27-2012, 09:36 AM   #11
Snik
Snik's Avatar
8.5s all around all around is ok too, i had that too, you can run staggered tires and spacers and still look good. i had 225 and 255s on mine. You could also FIND et35 18X10s if you want, or 9.5s.
Old 03-01-2012, 01:34 PM   #12
xfixkaos
My Ride: 00' 328i
Well I talked to my local speed shop they roll fenders and pull and al that goodness so as of right now I'm gonna get some coils lower my car and get wheels then pull the fender around the wheels prolly going to stick with the 10s in the rear I think it will look sick with the stagger gonna make a build thread about building on a budget haha raceland coils here I come lol
