Old 07-17-2011, 10:10 AM   #1
umermariner
My Ride: 1999, 328I
Oil Filter removal from plastic housing
Hello Guys,
Need help asap.. in the middle of an oil change (first time with this car, have done so many before)... Everything is done, but the oil filter is kind of stuck in the upper housing (I opened it with 36mm socket, but the oil filter came out with the housing and not coming out). There is a plastic rod coming out in the middle, I have tried rotating it in either directions... it rotates, but not sure how to take it out.. just dont want to apply force and break something .
Looked at threads, could not find anything.. please let me know ..
Thanks.
umermariner is offline   Reply With Quote
Old 07-17-2011, 10:13 AM   #2
E46_330i_Stud
My Ride: 2004 330ci ZHP 6MT
It just pulls right off the top. No extra work necessary.
1995 325i 5mt ArcticGrey/Dove - SOLD
2004 330ci ZHP 6MT SilberGrau/Black - SOLD
2001 330i M-Sport 5MT StaulGrau/Grey - SOLD
1992 Accord LX Sedan 275k miles all original - DAILY
2002 Chevy Suburban LT Autoride - TOY HAULER
2005 GMC Sierra 2500HD SLT - RACE TRUCK!
E46_330i_Stud is offline   Reply With Quote
Old 07-17-2011, 10:24 AM   #3
jdstrickland
My Ride: '94 325iC & '00 323i
You just pull the filter off/out. I have the E36, and the filter remains inside the canister when I take the lid off, but I think the E46 lid comes off and the filter comes out with the lid. Either way, you simply pull filter out/off.
Old 07-17-2011, 10:26 AM   #4
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: 335i
Pull them straight apart. Nothing will break. The filter more-or-less is wedged onto the cap.
-Gary
DiscoStu is offline   Reply With Quote
Old 07-17-2011, 10:51 AM   #5
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
twist and pull...works easier.
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 07-17-2011, 02:21 PM   #6
mack89
My Ride: '00 HellRot 323Ci
pull it hard and experience motor oil shower
mack89 is offline   Reply With Quote
Old 07-17-2011, 03:00 PM   #7
Sankekur
My Ride: 2004 330i
It just pulls out of the cover.
Sankekur is offline   Reply With Quote
Old 07-17-2011, 03:43 PM   #8
umermariner
My Ride: 1999, 328I
Thanks guys .. Once I applied force, it came right off. It was stuck pretty hard, and I was scared of breaking something by applying too much force .
Finally, oil change successful . However, I am still not able to reset the oil miles.. u know... Mine is 99, E46, and I read I need to ground pin 7 and 19 (if I remember correctly) for 3 seconds..however, tried it so many times, but not working ...
Will do more research and hopefully will do it in few days
Old 07-17-2011, 04:12 PM   #9
Sankekur
My Ride: 2004 330i
If I am not mistaken there is a way of doing the reset through the hidden OBC functions.
Old 07-17-2011, 04:31 PM   #10
jdstrickland
On the E46 cars, you press and hold one of the odometer buttons then turn the ignition to RUN. There are a number or writeups that explain the procedure, but grounding Pins 7 & 19 are not among them. Grounding pins is so E36 ...
Seriously...
Old 07-17-2011, 10:38 PM   #11
umermariner
My Ride: 1999, 328I
Seriously...
Did it .. but by grounding Pins .. the newer methods are applicable for 2001 and up models
Old 07-17-2011, 11:06 PM   #12
dan_1337
My Ride: 330CiC
I believe that the miles to service doesn't just indicate an oil change, but also indicates that other things need to be checked etc prior to it being reset.
dan_1337 is offline   Reply With Quote
Old 07-18-2011, 12:25 PM   #13
havnfun328
My Ride: 99 328i Stock
That's the way I do it on my 99.
2003 E39 M5 Lemans Blue: The most amazing car ever built
1999 E46 328i Bone stock 5-speed: Soon to be track rat
230K and still running strong
havnfun328 is offline   Reply With Quote
